Page 14 of 20 1 2 12 13 14 15 16 19 20
#415976 09/19/02 02:49 AM
Marty from MSDS has chosen a different ceramic coating process for these, more recent sets. The ones that you saw were most likely from the original process which is expected to be improved upon. It was a concern of mine too, but from what I've heard I'm confident these will last.
'98 Silver Frost SVT - #2089/6535 Some intake stuff, exhaust stuff, suspension stuff
#415977 09/19/02 05:24 AM
Yes good call cathode...ALSO Marty at MSDS provides a warranty and also, being a good busniess man is taking back headers systems that are PAST warranty and redoing them! He doesn't want dis-satisfied customers, also he want's them and everyone else to know that he has quality products that we all can depend on! ~!!!! Hope that helps your decision making out!~! And if you do want in...FEEL Free to fill a form out and mail it in with your money! Just make sure it's by the 30th!!!!
MY TOYS 98.5 Black/Midnight Blue SVT 2003 Yellow Honda CBR 600 RR 2004 Green/wht. Yamaha 740XL Waverunner Waiting on a hood, to see what my next step is for the SVT.
#415978 09/19/02 03:26 PM
ok...I was just looking at some pics of the headers/y pipe setup and realized that the high-flow cat currently on the car which is part of the Sho Shop Y pipe can't be reused, obviously, and the headers are made to be a straight bolt-on right? so that means I'll have to go back to using the stock main cat in between the MSDS headers/y-pipe and my Borla...correct?
I'm just trying to get the installation straight in my head. I'll be going from SHO SHOP Y-pipe w/ cat & Borla to the MSDS headers/y-pipe & Borla. The main difference being that the MSDS y pipe consists of merely the down pipes from the headers that go down to the where the stock cat would be...there will be a gap from there to the exhaust. I'm thinking as I'm writing here. So I need to make sure I still have that stock main cat sitting around or I'm in trouble.
#415979 09/19/02 03:32 PM
Ummmmmmm right ...I got lost in all that you said ! But i'm pretty sure i got it! And i think you might want to call MSDS about that and check, cause maybe you will still be able to use your Borla Cat! I don't know~? 518-507-027 There's the # to call and ask for Marty~
#415980 09/19/02 03:46 PM
yeah - and let us know when you find if you don't mind please.
I would like to know - since I currently have the SHO-Ypipe and Borla combo.
If I need to, I'll have to order a high flo cat..
Later!
Hugo ------ 98 SVT - 53k mi - SOLD 04 Mazda3 S 5-Dr
#415981 09/19/02 03:47 PM
a little confusing... I know.
what it boils down to is that the MSDS "y pipe" consists of merely piping, whereas the sho shop y-pipe includes a catalytic converter and a flex pipe and extends all the way back to the where the "cat-back" exhaust begins. A direct swap is not possible, the stock main cat will have to go back in to connect the MSDS "y-pipe" and the exhaust.
notice where the "y-pipe" stops
and SHO SHOP's y-pipe
#415982 09/19/02 03:57 PM
You do not want to use the MSDS headers in conjunction with the SHO y-pipe.
a) it voids the MSDS warranty
b) it sounds terrible (at least when I had MSDS->SHO y pipe-Bassani)
c) MSDS y-pipe (IIRC) provides more HP
Anyone getting the MSDS should seriously consider getting them jet coated. I know the "revised" coating is suppposed to be better, but I know there are a couple people with the "revised" coating that are seeing signs of rust:
MSDS "revised" coating rust pics.
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
#415983 09/19/02 04:06 PM
I agree with the first part, I intend on removing the SS y-pipe and either sticking the stock Cat back in or coming up with some other solution. Don't want to void that warranty then I'd really be up the creek if they do rust.
#415984 09/23/02 02:40 PM
would getting a CATCO High Flo Cat work?
I currently have the Sho Shop Y-Pipe installed....and so I need to make sure I get everything that is needed.
And - how is everyone doing with placing their orders?!?!
#415985 09/23/02 04:15 PM
only a cat won't solve the problem...it has to:
a) be the correct length
b) have a flange on either end
that's why sticking the stock unit back in would work fine. I'm assuming most people with the headers have that setup
(headers/y-pipe-->stock cat-->cat back exhaust).
I'm not sure what I'm going to do either, I just checked this weekend and it looks like I junked the stock cat when I installed the SHO SHOP Y....shucks
Moderated by  1314_dup1
