Page 3 of 3 1 2 3
Who cares if it is even 5%. So if your speedo reads 50, you'll be going 52.5? Wow....be careful not to speed. LOL. If you want to be anal, recalibrate the speedo.
Dan Acura Integra GS-R w/mods Former owner of a 95 SE
You should be fine... it will just vary between 1-2 mi (speed). But will vary about 100-200 miles on your odometer I think (over time)
Don't go larger than 17" otherwise you will need to get it recalibrated.... which involes opening up the transmission and playing on one of the gears.
just my advice
*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* 1997 Ford Contour GL 2.0L 4Cyl 133,000+ - Cold Air Intake - White Strobes in grille *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*
I am running 17" Cougar rims with 215 / 50 -17 tires. The only time I heard it rub was when I hit a Michigan pothole.
99 SE Sport..ATX SVT exhaust SVT zip tube and air cleaner assembly Tinted windows 17 Cougar Zn Wheels
As a former Furd Parts Techie, mod'd 'tour owner, and dedicated gadfly:
the "electronics" could give a damn less -- ECU just assumes you like running @ higher revs all the time!
Rubber mallet: presume Stazi is ref-ing banging in the lip on fender; works, but your local tire shop probably has a tool to actually roll the lip under, which is infinitely aesthetically more pleasing.
worried about rub? == a. measure your existing clearance w/wheels neutral (straight ahead), full right AND full left. Be sure to check inside [duh, back side of tires when looking at 'em from shiny side of car] as well as outside clearances. b. in each postion, also have cousin Bubba {250 pounds, no teeth & IQ to match wheel diameter} depress the suspension (gently sit on the corner) so's ya kin check when suspension deflected -- if'n ur real brave, have him bounce a bit while you have the tape measure in there. NOW: if using same rims, you can kinda fairly accurately judge what your new clearance will be if you check your new tire's section thickness (NOT just tread width); if you're plus sizing, make sure you have all your figures checked carefully for offset, as well as tread width & section width. Almost all manufacturers provide both measurements in their real spec sheets.
"oh it's too hard and uncomfy" -- refuse to comment. Go borrow your Uncle egbert's 1967 MG Midget or Bugeye and take a ten mile ride on most representative interstates: if the expansion joints don't knock your hemorrhoids off and change your pitch an octave, then come back & whine about a hard ride -- handling often has it's own price. Also -- put GOOD struts & springs on when doing a tire aspect-ratio change -- I personally can recommend Terry Haines "Koni ST200 kit". Firm but a five hundred mile stint still leaves the kidneys & gonads where they began.
If wide tread for nominal size is important & snow don't fly often, I also can't recommend Bridgestone S03's enough, unless tire wear is a major concern -- then go see Manny & rest of the pep boys for your 80000 miles bowling balls on rims.
My $0.02
SCCA WOR/OVR/NEOh Regions Race Control Marshall #53 Silver Street Touring S '98 Contour GL; 2.5l-5 spd Koni Kit - Sport Struts w/progressive sport springs from HMS!! Custom 24-mm Rear Sway also from Terry BAT Camber/Caster through HMS PF Spherical Ball End Links Bridgestone S-03's Grizzly Clutch lightened SVT flywheel (Thanks KnuConceptz) DMD from incomparable Terry Haines! K&N & Dynomax Mintex pads Chris Hightower Rear Strut Tower Bar
Page 3 of 3 1 2 3
Moderated by  1314_dup1
