Posts: 355 |
Originally posted by SVTnKC: Showtime..... you get my check yet?!?!?!?!??!
It didn't come Saturday....maybe today...i won't get home to check my mail until 5-5:30, so i'll let you know tonight or tomorrow.
2000 SVT (silver)
#1529 of 2150
yeah...its modded
"having no way as way and no limitation as limitation"
Posts: 355 |
I got it yesterday....i'll probably be sending it out tomorrow (Wed.) Have to see when my friend with the truck can take me.
2000 SVT (silver)
#1529 of 2150
yeah...its modded
Posts: 511 |
MY TOYS
98.5 Black/Midnight Blue SVT
2003 Yellow Honda CBR 600 RR
2004 Green/wht. Yamaha 740XL Waverunner
Waiting on a hood, to see what my next step is for the SVT.
Posts: 355 |
Hoods sent out yesterday
Eric G. Jason B.
2000 SVT (silver)
#1529 of 2150
yeah...its modded
Posts: 511 |
MY TOYS
Posts: 511 |
 Well i did this to my hood latch~ Just like 1314 did~ Then i also had to sand my latch on the CF hood down alittle, because it was bent to the side a little and too fat to fit into and latch down~ Other than that she lines up PERFECT! i'll send in some pics when i get them developed!!!
MY TOYS
Posts: 355 |
these hoods will be going out on next shippment
Jason B. going to Pontiac MI. greyhound Nick J. going to Islip NY. greyhound Matt B. going to King of Prussia PA. greyhound
I'll let you know when my friend can take me downtown in his truck. sorry for the delay.
2000 SVT (silver)
#1529 of 2150
yeah...its modded
Posts: 2,369 |
After you dremel the latch can you still use the stock hood? I plan on changing hoods from the stock one to carbon fiber every now and then. Would I still be able to do that after the latch is dremeled?
98 Lime Green SE w/SVT Kit, Projectors, CF Hood, 18" Rims, GC's, Shaved, System
98.5 Silver SVT #5737 Black FSVT Rims, MSDS, BAT Drop
85 Toyota PU Lifted
06 GSX R 600 Black/Silver
My Rides
Posts: 5,975 |
Originally posted by skrilla187: After you dremel the latch can you still use the stock hood? I plan on changing hoods from the stock one to carbon fiber every now and then. Would I still be able to do that after the latch is dremeled?
The latch loop on the CF hood needs to be dremeled - it's too thick (compare the loops between the CF and OEM hoods).
The holes in the latch need to be enlarged/moved so that the CF hood will lock.
If/when you decide to put the OEM hood back on, you will have to loosen the screws on the latch and move it back to the OEM position, and vice versa.
HTH
Posts: 2,517 |
Originally posted by SVT ST PETE: The latch loop on the CF hood needs to be dremeled - it's too thick (compare the loops between the CF and OEM hoods).
HTH
I haven't even started to attempt my CF hood install (don't want anyone to mess it up when the 3.0L goes in) but I was wondering: instead of dremelling out the latches on the hood is it possible to move the mounting points on the car up by removing and butt-welding back onto the frame? Might look cleaner... Any thoughts Pete??
