#41477 05/03/02 01:18 PM
Z
Z
ok....i did the mystery mod back in xmas time....now that weather is better i rolled down my windows and i noticed i have a profound rattle sound coming from the exhaust...i thought i had noticed before but too lazy to roll down window at time....but was wondering if anyone might have an idea to get rid of this annoying rattle that happens in the rpm range between 2900 and 4000 rpms weird to me....anyone have any ideas?????
cam
cool
98 tour SE
Resonatorless
Gutted cats
some speakers
A little bobbin head cat watchin every1 pass
and ford mud flaps(darn fishin trips keep me muddy)
added all terrain tires(i like to pretend im rally racing, whne not really racing)
#41478 05/03/02 01:29 PM
Sounds like you haven't fully removed the ceramic lining from inside the pre-cats, or you have a new problem with your main cat. And if you have a problem with your main cat making that noise then you probably have a problem with your fuel system as well.
2000 Contour 2.5L ATX (Medium Steel Blue)
Items for Sale
  • SVT Indiglo Guages (NEW)
  • Traction Control/Rear Defrost Switch (NEW)
  • V6 Speedometer/Guage Cluster w/ Tach (51k miles)
#41479 05/03/02 01:38 PM
Rattle or buzz? I get a buzz from my mystery mod at certain rpms (resonance).
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#41480 05/03/02 03:15 PM
Z
Z
its a rattle sound...doesnt sound like rasp...its almost like the exhaust sheild is bumping around or something....i have undone the exhaust and nothing in the pre cats...so maybe i need a knew cat alltogether or something....the rattle only occurs in gear while moving of course....i cant get it to do the rattle while sitting parked.....?????
98 tour SE
Resonatorless
Gutted cats
some speakers
#41481 05/05/02 12:36 AM
Might be ping too....
Try regane or an octane booster or hi-test gas. If rattle goes away, then you have a pinging problem.
If not, somethings loose.
"My Name is Richard. I am a Contouraholic."
1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades;
Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod;
PIAA 9006 Super White Headlamps
AIWA CDC-MP3 HU; WeatherTech Mats
Viper 600ESP w/Remote entry
#41482 05/05/02 12:40 PM
I had a rattle like the one you described. It turned out to be the heat shield on my cat. Its to prevent grass fires.. or something like that. I just took it to a muffler shop and they popped it off for me.. They told me it was pointless to keep it on. Good luck.
metallic teal 95 mystique V6 ATX
debadged-no door dings-K&N filter-no hoodliner-SVT exhaust (thanks steve!)- Powdercoated Black E1s -SE side skirts in the garage! LED stereo and door handle lights
