Posts: 3 |
I noticed since last week whenever I gas to around 70MPH it makes a weird vibrating noise. It vibrates the floor and gas pedal and making a quick rattle-type noise. The engine light is not on.. I have no idea what is wrong. Even if I let go of the gas at 70, it will still make the noise alittle and then stop until I gas it again. Also... when I accelerate I can "feel" it coming too... it just sounds different. Any ideas on what this could be?? It couldn't be the wheel bearing could it?
Posts: 3 |
bump and update - when i say i hear it "coming" i meant that the acceleration noise isn't how it use to be.. anyone have any ideas on this? give it a shot! i'm willing to try ANYTHNG!!!
Posts: 131 |
i have this problem to when i get around 60 MPH...i assume its my tires...they need to be changed or rotated or something....its a pain in the asssssss....
99 Sport-Silver Frost
*SVT Ground Effx *30% Tints
*SVT Exhaust *Tinted Rear Reflector
*KKM Intake *Modded Silverstars
*Magnaflow Res. #10425 *Wood Grain Kit
Posts: 305 |
when my car got out of alignment after hitting a curb I had that problem severly at highway speeds. It could be something as simple as that.
Posts: 1,044 |
Your rattle/vibration in the footwell could be a loose heat shield on the main cat or something else on or around the exhaust & y-pipe. If you feel it in the steering read on... I had a humming noise and slight vibration that would grow in intensity from about 35 to 60 MPH. After replacing one wheel bearing and starting on the second one, I discovered the left side inner CV joint was very worn. This was around 120K miles, so the wear was not unexpected. NAPA has the axles for about $65 and it's quiet as mouse now!
Posts: 18 |
Did you replace the axle yourself? I just did my left axle and it was a Major PITA.
GalaxyEng
95 SE MTX Electric Red
2001 Corvette Z06 Torch Red/Z06 black
2000 Lightning Red
2003 Jeep Liberty
Yes, I like Red Cars!
Posts: 1,044 |
Yeah, left side.  I was already in the process of pulling the knuckle, so it wasn't too bad. I had to get a loaner slide hammer with a reverse claw clamp (autozone) to get the inner u-joint cup out of the tranny.
I feel Guilty, Oh so guilty
Posts: 4,789 |
Was your girlfriend in the car with you at the time?
-Mitch Hedberg
