As a side note Airnight, use the "2.5" crank position sensor wheel position when you slide it onto the crank. Even though you are timing a 3.0, you are using the 2.5 front timing cover which locates the crank position sensor in a far different location than the factory 3 liter timing cover does. Just pretend it's a 2.5 you're rebuilding...
