The part everyone is missing is that the Electrical devices, especially transformers, use power (Watts). Watts= Volts x Amps (on DC, on AC, you have to adjust for impedance, but the principle is the same). As the volts are reduced, the amps increase to maintain the same amount of watts. For instance, I have a 12V to 120 Volt inverter that rated at 350 Watts. At 12VDC input, it draws 29.2 Amps on the 12v side, At 14VDC input it Draws 25 amps, at 10VDC it draws 35 Amps. If I have 30 amp rated wiring, it is ok at 12V and 14V, but could/would melt at 35A. This all assumes a 350 Watt load on the 120V side. Since the indiglos are a "fixed" load, I would assume they sized the components close to the normal full load (amps) rating. By undervolting, you are increasing the amps and if not burning up the unit, at least shortening the lifespan significantly. So, If you expect the unit to last 10 years, you might be shortening the life to 3 years. The fact that you have been undervolting for 1 year with no consequence just means you haven't waited long enough.
There's more to this, input impedance, output impedance, output load, extc, but I just kept it simple.
