Posts: 131 |
hey whats up guys...well my headlight is out, actually the passenger side low beam...well i changed the bulb..and it wasnt that,,,,next i checked the fuses.....not that either...what could it be....should i just take it to get looked at...could it be the wiring...any info would be great...thanx....
99 Sport-Silver Frost
*SVT Ground Effx *30% Tints
*SVT Exhaust *Tinted Rear Reflector
*KKM Intake *Modded Silverstars
*Magnaflow Res. #10425 *Wood Grain Kit
Posts: 1,603 |
You could of also gotten a new bulb that was bad. I would try another bulb.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 2,319 |
Check for volts at bulb connector would be the place to start. I assume you checked fuse 15, engine compartment fuse box.
Posts: 1,840 |
Did you check the fuses under the dash or under the hood?? There's a fuse for each high and low per light under the hood, IIRC...
Posts: 131 |
i did check the fuses..and i used 2 bulbs and it still didnt work...i guess ill try one more bulb i have here...if not then it will have to get looked at by a mechanic,,thanx for the info guys
Posts: 1,541 |
From the Service Manual:- Check fuse 15. DONE
- Check voltage at headlamp connector. You want to check between the ORANGE/WHITE wire and ground. Should be greater than 10 volts. If OK, go to the next step. If not, you have an open in the power circuit somewhere.
- Check for open in ground of headlamp circuit. You want to check the resistance from the BLACK wire to ground. If the resistance is greater than 5 Ohms, then there is an open in the ground circuit.
If the above checks out, all the manual says is to check the bulb. In reality, these are the only things that could be wrong, but finding the open in the headlamp circuit is easier said than done if it is determined one is present. Who says UBB Code isn't any good? I like the ability to put colors in. Nice addition to the functionality.
Posts: 131 |
i went through all the processes u just said..and what do u know....i checked the fuses again...and it worked...it was weird.. that was one of the first things i looked at(fuses) oh well ....i guess things have a way of working themselves out...
