Page 3 of 7 1 2 3 4 5 6 7
I just payed you.
1998 Silver Frost CSVT #4014 Some mods My car
O
onosway Offline OP
O
keep em comming
MY NEW HOBBY...RUINING CHRIS CROFTS LIFE...
How many do you have so far?
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
O
onosway Offline OP
O
I think 4 so far, but the cut off date is still September 18.
Paypal'd
'98 Silver Frost SVT - #2089/6535 Some intake stuff, exhaust stuff, suspension stuff
O
onosway Offline OP
O
Originally posted by Cathode:
Paypal'd
For some reason I didn't get a confirmation e-mail from PayPal on this but not to worry it's in the account.
For the newbies (oh right, we're all newbies!), do you guys know how to take out the old emblem?
Ingredients:
1. Patience
2. 2 really flat heat screw drivers (small and thin)
3. Using one of the screw drivers pry around the emblem
4. Using the other one, pull/wedge out the emblem
5. Continue 3 and 4 with great patience! Do not scratch the chrome strip.
6. Remove black adhesive and clean off
To apply the emblem use some strong expoxy, jb weld or something crazy like that. Do not use double sided foam tape since it will raise the emblem and will take away from the flush look (OEM as one member said). There is some play top and bottom (1mm or less) on the emblem so leave your trunk raised and center the emblem and let sit for the hardening process (prob 20 minutes or so depending on what you used). Let it cure over night and you are set!
Is there no type of double sided tape that will work? The epoxy will make it an unreversable mod. I'm just curious, I intend on using the epoxy.
O
onosway Offline OP
O
This was just a personal preference. Without taking off the tape backing insert and see if you like it. I personally thought it looked OEM with it set more inside the oval.
hey man, $40 for the rear emblem. Do can you get one for the front grill as well? Also, can you take billpoint, Or just paypal? Lemme know I'm interested.
Tim
O
onosway Offline OP
O
e-mail me and we can work something out but yes I am only accepting PayPal and or check (however, if you send a check I must verify funds before item is shipped)
Moderated by  1314_dup1
