Originally posted by Cathode:
Paypal'd
For some reason I didn't get a confirmation e-mail from PayPal on this but not to worry it's in the account.
For the newbies (oh right, we're all newbies!), do you guys know how to take out the old emblem?
Ingredients:
1. Patience
2. 2 really flat heat screw drivers (small and thin)
3. Using one of the screw drivers pry around the emblem
4. Using the other one, pull/wedge out the emblem
5. Continue 3 and 4 with great patience! Do not scratch the chrome strip.
6. Remove black adhesive and clean off
To apply the emblem use some strong expoxy, jb weld or something crazy like that. Do not use double sided foam tape since it will raise the emblem and will take away from the flush look (OEM as one member said). There is some play top and bottom (1mm or less) on the emblem so leave your trunk raised and center the emblem and let sit for the hardening process (prob 20 minutes or so depending on what you used). Let it cure over night and you are set!
