Page 2 of 5 1 2 3 4 5
i was gonna order one last week but my girlfriend made me buy groceries instead.....damn food frown
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
I toldya - just do it!
AL
Red '98 SVT E0 3098/6535
KKM, Elizabethan EGR Plate, TH fix
OMP front brace
Hightower rear brace
DMD
B&M with reverse lockout disabled and centering spring removed
Mobil 1 oil and trans fluid
A6 Side Markers, Optima orange, Horn recontent
Painted Sail Panels
VooDoo Knob and pedals, RogerR deadpedal
Blau Houston & CD changer
Cup holders that work
Donnelly mirror
BAT Sill Plates
and a Bullitt fuel door
yep yep yep......I know the dude that had his hands on the testing of that part or something like that wink
Just call me Judge.
People suck.
Life begins at 170mph...until that point it is just boring.....
Is this DMD heavier than what its replacing? Seems like everybody wants to lighten up there pullies, and now one comes out that s/b heavier since there is an extra piece on it, and everybody loves it.
Should we notice any performance decline because of the DMD? Im sure the smoothness of the revs and the reduced chances of 'crank whip' negate that, but im just wondering.
Jon - NJNeco
2000 Silver Frost Cougar v6 MTX
Dyno Tested 173.6 whp - 161.2 wtq
Visit MaStaMooN.Com for Details! *Back up in a limited form*
Ditto! WOW. Unbelievable. So smooth gotta watch tach to keep from hitting brick wall of limiter.
Yes, heavier, but so, so, so smooth. Besides, not sure of the dynamics of being at that end of crank. Sure doesn't seem to affect how mine pulls revs. In fact, w/much lighter flywheel I put on at same time,m it hits 6750 so fast I can't believe it!
SCCA WOR/OVR/NEOh Regions
Race Control Marshall
#53 Silver Street Touring "S" '98 Contour
GL; 2.5l-5 spd
"Koni Kit - Sport Struts w/progressive "sport" springs" from HMS!!
Custom 24-mm Rear Sway also from Terry
BAT Camber/Caster through HMS
PF Spherical Ball End Links
Bridgestone S-03's
Grizzly Clutch
lightened SVT flywheel (Thanks KnuConceptz)
DMD from incomparable Terry Haines!
K&N & Dynomax
Mintex pads
Chris Hightower Rear Strut Tower Bar
The mass is all pretty close to the axis of rotation, so not much extra rotational drag I guess. I'm not worried -I ordered mine today laugh
Black E1
Reynoldsburg huh, I live in Reynoldsburg. You have PM.
2000 CSVT #1172 of 2150
Toreador Red...Birthday -> 1/4/2000
*Indiglo Gauges
*Drop in K&N
*Sylvania SilverStar Highs in Lows
*Fog light Fix
*Pioneer Premier P730
*Sound by Audiobahn
*White HVAC Panel
*Security via Ungo MS2007
*Elky Mesh Mod
DemonSVT check weights - DMD is 1 lb heavier than stock damper. Because it is a small radius pulley it will have much less effect of reving/power than say 1lb added or lost from a large radius flywheel for example. Basically negligable change in the speed in which the engine spools up. Infact, several companies than make aftermarket dampers (such as Fluidamper) claim power increases from reduced crank bending friction. Not to mention the REAL value here - less wear on bearings the "Achilles Heel" of the Duratec. Extra smoothness is just a nice side effect. Runs smooth as a BMW now (seriously).
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
I posted these questions yesterday, maybe the server maintenance made them go bye-bye.
smile
A previous post said that Ford dealers would install these? Should I trust them? I'd prefer the work be done by a dealer. Or is there a garage you can recommend in Cleveland, Terry?
I just want to figure out who's gonna put it in before I buy it.
Brian Dors
99 SVT
F
F
Any decent mechanic that understands Ford's torquing procedures and a lift makes it awhole lot easier. My cousin shop manager/mechanic of tranmission shop (Mansfield) helped me do mine. The hardest part for me was getting the poly-v back on. Don't forget the RTV silicon in the keyway.
Paul
I'd sweare my motor feels even smoother on the bottom end, also???
Paul
