Posts: 1,445 |
i was gonna order one last week but my girlfriend made me buy groceries instead.....damn food
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 345 |
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 2,794 |
yep yep yep......I know the dude that had his hands on the testing of that part or something like that
Just call me Judge. People suck. Life begins at 170mph...until that point it is just boring.....
Posts: 242 |
Is this DMD heavier than what its replacing? Seems like everybody wants to lighten up there pullies, and now one comes out that s/b heavier since there is an extra piece on it, and everybody loves it.
Should we notice any performance decline because of the DMD? Im sure the smoothness of the revs and the reduced chances of 'crank whip' negate that, but im just wondering.
Jon - NJNeco 2000 Silver Frost Cougar v6 MTX Dyno Tested 173.6 whp - 161.2 wtq Visit MaStaMooN.Com for Details! *Back up in a limited form*
Posts: 33 |
Ditto! WOW. Unbelievable. So smooth gotta watch tach to keep from hitting brick wall of limiter.
Yes, heavier, but so, so, so smooth. Besides, not sure of the dynamics of being at that end of crank. Sure doesn't seem to affect how mine pulls revs. In fact, w/much lighter flywheel I put on at same time,m it hits 6750 so fast I can't believe it!
SCCA WOR/OVR/NEOh Regions Race Control Marshall #53 Silver Street Touring "S" '98 Contour GL; 2.5l-5 spd "Koni Kit - Sport Struts w/progressive "sport" springs" from HMS!! Custom 24-mm Rear Sway also from Terry BAT Camber/Caster through HMS PF Spherical Ball End Links Bridgestone S-03's Grizzly Clutch lightened SVT flywheel (Thanks KnuConceptz) DMD from incomparable Terry Haines! K&N & Dynomax Mintex pads Chris Hightower Rear Strut Tower Bar
Posts: 332 |
Originally posted by MaStaMooN: Is this DMD heavier than what its replacing? Seems like everybody wants to lighten up there pullies, and now one comes out that s/b heavier since there is an extra piece on it, and everybody loves it.
Should we notice any performance decline because of the DMD? Im sure the smoothness of the revs and the reduced chances of 'crank whip' negate that, but im just wondering. The mass is all pretty close to the axis of rotation, so not much extra rotational drag I guess. I'm not worried -I ordered mine today
Black E1
Posts: 869 |
Reynoldsburg huh, I live in Reynoldsburg. You have PM.
2000 CSVT #1172 of 2150 Toreador Red...Birthday -> 1/4/2000 *Indiglo Gauges *Drop in K&N *Sylvania SilverStar Highs in Lows *Fog light Fix *Pioneer Premier P730 *Sound by Audiobahn *White HVAC Panel *Security via Ungo MS2007 *Elky Mesh Mod
Posts: 3,248 |
Is this DMD heavier than what its replacing? DemonSVT check weights - DMD is 1 lb heavier than stock damper. Because it is a small radius pulley it will have much less effect of reving/power than say 1lb added or lost from a large radius flywheel for example. Basically negligable change in the speed in which the engine spools up. Infact, several companies than make aftermarket dampers (such as Fluidamper) claim power increases from reduced crank bending friction. Not to mention the REAL value here - less wear on bearings the "Achilles Heel" of the Duratec. Extra smoothness is just a nice side effect. Runs smooth as a BMW now (seriously).
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 111 |
I posted these questions yesterday, maybe the server maintenance made them go bye-bye. A previous post said that Ford dealers would install these? Should I trust them? I'd prefer the work be done by a dealer. Or is there a garage you can recommend in Cleveland, Terry? I just want to figure out who's gonna put it in before I buy it. Brian Dors 99 SVT
Posts: 656 |
Any decent mechanic that understands Ford's torquing procedures and a lift makes it awhole lot easier. My cousin shop manager/mechanic of tranmission shop (Mansfield) helped me do mine. The hardest part for me was getting the poly-v back on. Don't forget the RTV silicon in the keyway. Paul
I'd sweare my motor feels even smoother on the bottom end, also??? Paul
