#410599 08/16/02 04:03 AM
Just got exhaust res removed for $30, cheapest I could get. Guy said there is no way to put a hi-flow cat on it?!? Isn't he wrong? He said there would be no way to bridge from manifold to cat under the car. Anybody with how-to on doing sway bar switch, and front and rear bushings switch, tell me. Also, I removed part of dealer sticker and you can see the outline of where it was. What do I do to fix that? How much longer for street flight CAI? Oh yeah, it's good to be back...(formally Redcon96I4)
#410600 08/16/02 04:06 AM
I just realized it says redcon96I4 now..but in the zetec page it still shows kremithefrog... what's up with that?
#410601 08/16/02 05:18 AM
CEG road warrior
CEG road warrior
You can put a high flow cat on you would just have to move the flex pipe. My high flow cat is under the car (since I have the header) and my flex pipe was removed. I will be putting one on very soon. I don't like the rasp.
#410602 08/16/02 05:13 PM
In reply to:
Build #2 went on my car last night. It's a much cleaner install. Hope to dyno it after I get back from Vegas (gotta let the car warm up to it).
How many Vs would a VTEC TEC if a VTEC could TEC Vs? The one, the only....FRNKNFORD http://www.westvalleycs.com
#410603 08/17/02 08:37 AM
In reply to:
Goo Gone and a new coat of wax did wonders for me.
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
#410604 08/17/02 08:44 AM
CEG road warrior
CEG road warrior
I stuck a Zetec badge were it was.
#410605 08/18/02 04:15 AM
X
X
Sorry for the newb question as of now i have no archives to look @ If i get the Resonator cut on my zetec (2.0 I4 ) will i have rasp/drone/any probs if so how do i overcome these problems?
xoom
'98 Ford Contour Mods: Audio: JVC kdlx-100 4 Pioneers 2-180 and 2- 200 watt speakers Meguiars Car wax http://www.secnut.com
#410606 08/18/02 03:29 PM
Yes, basically you want to replace the stock resonator with a straight thru muffler or a "real" (efficient) resonator/muffler like a Edelbrock.
-Giovanni One turbocharger. Two intercoolers. All love.
#410607 08/19/02 01:09 AM
I used goo gone but it left an outline where the sticker was. I'll probably eventually put an emblem there,but I don't know when. I'm also afraid to remove my pin stripes if it's gonna leave an outline. And about the removing resonators, unless you really have problems with strange noises or if you just have plenty of money to spend, don't worry about gettin' something to take the noise away. It's an improvement over stock no matter how you look at it.
#410608 08/19/02 01:22 AM
Bare in mind that I can't look at your car in person but from the sound of it what you have left isn't residue. The line you described sounds like paint fade. I'm assuming your car is one of the dark red colors they offered on 96's(another assumption). Most of the darker colors have shown little resistence to paint fading over time. What you might try is to buy some paint cleaner(Mothers has a good one)and rub that in very good all around the border of where the badge used to be. I'm guessing the paint may be darker where the badge was than everywhere else so you need to use the cleaner all around that area and see if it helps. Paint cleaner should be followed by a good polish to see if it helped at all. HTH.
#410609 08/19/02 01:33 AM
Car=toreador red..it's more of an outline of the sticker. the paint is the same. it's like someone took a pen and drew around the sticker(not pen color though) ...thanks for the help.
#410610 08/19/02 01:54 AM
Oh okay, that makes sense too. I'm surprise the goo gone didn't take care of that. It sounds almost like a chemical from the sticker ate at the clear coat on the edges. Or maybe other chemicals set and evaporated around those edges leaving a nasty residue that damaged the clear coat. Like soap or window cleaner ran down to the sticker and just lingered on the edges instead of being washed away. ??? Got me, wish I could offer more advice.
Moderated by  Loco4G63
