Page 3 of 3 1 2 3
#410422 08/20/02 06:49 PM
I used tools... Don't know about the right tools... I used all that I had and that worked... I used Zip Ties to hold the cams in place. It is a little intimidating but well worth the knowledge you will pull out of it... If you have any questions feel free to drop me a line I will e-mail you my Number if you have any questions... Good Luck..
John Was 96 Contour Zetec RIP Now 2001 Chrysler 300M.... I Will Have Another Soon... I AM NO TRADER......
#410423 08/20/02 06:54 PM
I figure all of the tools aren't absolutely necessary since Ford tends to invent tools that aren't totally necessary in order to make a job seem more difficult than it is. But when it comes to my engines timing I don't like taking chances. I'd greatly appreciate a number so I could call you if I run into anything.
sqplus@my99svt.net
#410424 08/21/02 06:16 AM
CEG road warrior
CEG road warrior
Originally posted by Sleeper:
VCT = Variable Cam Timing
Kind of like Honda'a VTEC, just a bit more basic.
The VCT is an emissions thing. Replaces the EGR. VTEC is more for power but I'm sure it helps emissions too. Sorry for getting offtopic.
#410425 08/21/02 06:13 PM
I paid 300$CDN(200orlessUS) to replace 1)the timing belt(I bought 60$CDN), 2)the fan belt(He Supplied), 3)missing springs and bolts from the timing belt(YIKES! no wonder it was slapping the cover ), 4)also a new water pipe(he suppied), so 250$ US seems like a bit much to me. That's quite the run on sentence isn't it?
Alec
'95 GL Zetec ATX PM Me for pre-98 parts, my parts car must go!
#410426 08/21/02 06:30 PM
I have not had one problem yet and it was about a year ago..
#410427 08/22/02 03:09 AM
Believe it or not, the spring and bolt on the tensioner are supposed to be missing. Once the tensioner is tightened down, you could take the spring and bolt back out again if you wanted, without affecting operation.
Originally posted by David L:
There is a threaded nut that is a PITA to replace. You need a certain size crows foot to get to it, and nobody sells it
  It seems that nobody sells a 22mm crowfoot wrench, which is the correct wrench to use there.  Howver, Sears sells a 7/8" crowfoot wrench, which is close enough.
Hyster E60XM-33 1996 Mercury Mystique GS, Zetec, ATX To email me, remove the string HatesSpam from this address:BobHatesSpam@Blaylock.to
Page 3 of 3 1 2 3
Moderated by  Loco4G63
