#40987 04/15/02 12:02 AM
Since the topic was brought up that both the Shoshop and BAT y-pipes aren't insulated, I found two brands of exhaust wraps: DEI and Thermo-tec. Has anyone used either, and is one better than the other? They have similar pricing so Im guessing the products are pretty much the same.
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
#40988 04/15/02 12:15 PM
Anybody? Id like to use this too, if possible.
98 E0 Silver SVT
KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
#40989 04/15/02 02:45 PM
Thermotec is good.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#40990 04/15/02 03:10 PM
F
F
I'm going with Thermo-tec
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
#40991 04/15/02 03:19 PM
i'm using the DEI, 2in exhaust wrap, double wrapped.
Silver 98.5 SVT
5/19/98, 6023
#40992 04/16/02 12:00 AM
Why would exhaust wrap void most header warranties? confused
#40993 04/16/02 12:15 AM
Don't waste your time and money guys. I ordered the Thermo-Tec for my y-pipe and it did absolutely nothing! The oil temp stayed the same. Just a waste of time, and out $50.
Chris
NJ
98.5 SVT Silver Frost w/Frankentrans
carsla AT optonline DOT net
#40994 04/16/02 12:31 AM
Well, at least your bad news saved me $50. So what can we do about this whole problem? Short of buying and installing a monster oil cooler?
#40995 04/16/02 06:06 AM
Originally posted by PA 3L SVT:
[b]Don't waste your time and money guys. I ordered the Thermo-Tec for my y-pipe and it did absolutely nothing! The oil temp stayed the same. Just a waste of time, and out $50.
Well, at least your bad news saved me $50. So what can we do about this whole problem? Short of buying and installing a monster oil cooler?[/b]
Well, I'll let you know during SZ. HMS will have my car two days prior to make some changes... smile
Chris
NJ
#40996 04/16/02 08:39 PM
I really need to check the temp on mine to compare with others.
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
