Posts: 1,181 |
Since the topic was brought up that both the Shoshop and BAT y-pipes aren't insulated, I found two brands of exhaust wraps: DEI and Thermo-tec. Has anyone used either, and is one better than the other? They have similar pricing so Im guessing the products are pretty much the same.
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
Posts: 1,036 |
Anybody? Id like to use this too, if possible.
98 E0 Silver SVT KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
Posts: 3,237 |
Posts: 583 |
I'm going with Thermo-tec
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 82 |
i'm using the DEI, 2in exhaust wrap, double wrapped.
Silver 98.5 SVT 5/19/98, 6023
Posts: 1,181 |
Why would exhaust wrap void most header warranties?
Posts: 1,028 |
Don't waste your time and money guys. I ordered the Thermo-Tec for my y-pipe and it did absolutely nothing! The oil temp stayed the same. Just a waste of time, and out $50.
Chris NJ 98.5 SVT Silver Frost w/Frankentrans carsla AT optonline DOT net
Posts: 3,419 |
Originally posted by Shaggy: Don't waste your time and money guys. I ordered the Thermo-Tec for my y-pipe and it did absolutely nothing! The oil temp stayed the same. Just a waste of time, and out $50. Well, at least your bad news saved me $50. So what can we do about this whole problem? Short of buying and installing a monster oil cooler?
Posts: 1,028 |
Originally posted by PA 3L SVT: Originally posted by Shaggy: [b]Don't waste your time and money guys. I ordered the Thermo-Tec for my y-pipe and it did absolutely nothing! The oil temp stayed the same. Just a waste of time, and out $50. Well, at least your bad news saved me $50. So what can we do about this whole problem? Short of buying and installing a monster oil cooler?[/b]Well, I'll let you know during SZ. HMS will have my car two days prior to make some changes...
Posts: 1,041 |
So what can we do about this whole problem? Short of buying and installing a monster oil cooler? I really need to check the temp on mine to compare with others.
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
