Posts: 1,611 |
Suspension Modifications
Koni Adjustable Struts Eibach Lowering Springs EBC Greenstuff Brake Pads 24 MM Aussie Bar- Rear Sway Bar ¼ Metal sway bar backing plates Poly end link bushings ES Motor Mount Insert 245/45/16 Yoko AVS Tires 5 MM spacers at rear wheels Tubular Steel Adjustable Rear track arms Energy Suspension Rear Control Arm, Front and Rear Sway Bar bushings EBC green front and rear pads Stainless brake lines
Drivetrain & Performance Modifications
BNM prepped 3 liter block 3 liter heads SVT Cams, w/ water pump drive removed Cunningham Chrome Molly Rods with upgraded rod bolts Trimetal rod & main bearings Dual Mode Mondeo Damper SHO Shop lightened Billet Flywheel Crank Knife Edged and motor balanced by Horn Race Engines RAM Automotive Metal Pucked clutch and HD pressure plate 2000 Model Year Transmission HMS Inc. Mark III transmission update w/ full lube system & Zetec Final Drive Ratio Quaife LSD installed by HMS Inc Driveshaft Shop level III CV shafts with custom hubs 42 lb Ford Racing Injectors MSD Dis-4 ignition Control Water Injection Kit Accusump 2 qt accumulator Remote mount oil filter Apex-I SAFC Ford 9MM Plug Wires B & M short Shifter 75 MM Pro-Flow MAF 65 MM Throttle Body 2.5” True Dual Exhaust w/ Magnaflow race series mufflers Vortech Supercharger w/ upgraded shaft Autometer Phantom gauges including A/F Ratio, Oil Pressure, Oil Temp, and 5” monster tach w/shift light. 4 point Safety Harness Enhanced pre-cats Dual Honed SVT upper intake Trunk mounted battery
Aesthetic Modifications
BNM Polished stainless sill protectors Removed door ding guards Foglights run w/o head lights BNM colored Gauges and HVAC Panel Powdercoating of Various interior, exterior, and engine bay pieces by BNM Billet Pedal Kit including dead pedal 15% window tint Body color matched grilles at all locations SVT Emblem at hood grille Custom Front Fender Badging SSR GT1 series 16” Rims PIAA 510 Driving Lights
Enjoy, Rick
The first Blown 3 Liter! "Drive it till the wheels fall off" -my personal motto!!!! 98.5 T-Red SVT #6180 Many Mods Buckshot77@aol.com Owner of 00 #1611 Silver Totalled on 10/7/01 SVT Parts for Sale
Posts: 4,983 |
P. Valdez 1998 VW Jetta TDI 1.9L I4 direct injection turbo diesel 5 speed manual no mods, no money AIM:PackRatTDI My exhaust smells better than yours.
Posts: 1,611 |
Just imagine if I added that to my sig! LOL
Posts: 4,983 |
Originally posted by Buckshot77: Just imagine if I added that to my sig! LOL I double dog dare you!
Posts: 348 |
Originally posted by PackRat: Originally posted by Buckshot77: [b]Just imagine if I added that to my sig! LOL I double dog dare you! [/b]Lol!
Da Stealth Moblile
Posts: 1,611 |
I think Rara would ban me for life for using up too much bandwidth. that and all those mods might be considered on the verge of pornographic for all you other caraholics.
Rick
Posts: 307 |
Originally posted by Buckshot77: I think Rara would ban me for life for using up too much bandwidth. that and all those mods might be considered on the verge of pornographic for all you other caraholics.
Rick Yummmmmmmm....car porno
'99 Contour SE V6 w/MTX (Black Clearcoat) '02 Dakota 4.7L V8 2WD X-Cab (Flame Red Clearcoat)
Posts: 1,611 |
Isn't that what auto-erotica is?!
Posts: 437 |
HOLY CRAPO!!!! You've probably got more money in mods then I paid for my car. Thats awesome!!! When is she gonna be ready to go? I'm anxious to come up and see her!!
"Nothing like coming off the on ramp in 3rd gear. Just let her eat and enjoy the awesome sound she makes. Ahhh, the joys of an SVT." '98 SVT #3754
Posts: 567 |
I am proud to say, "I have seen it!"
CURRENT RIDE: 95 GL FORMER RIDE: 99 SVT ( www.mysvt.com) "You only live once, but if you lived my life, once would be enough." -Frank Sinatra
