Posts: 852 |
First, I'd like an idea of the cost for this part, and maybe even the necessary brackets. I`d really like to retrofit it to my car...
Anyone have one in hand? I'm wondering what the hole size and hole to hole dimensions are?
Is this as harsh as a gas shock absorber? Softer? What is the approximate cartridge dimension?
The engine roll is getting pretty old on my car, and I would like to avoid filling the rear mount with urethane, to prevent undue vibrations.
TIA
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 316 |
On the Performance Fords website, it looks like we SE owners might be in luck for a torque brace to place on the engine to help vibration.
Try calling them for a price and ETA.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 1,428 |
Marco, you can have mine if you want.. leaking oil and all.. :rolleyes:
I need a replacement and I think it was a LOT more expensive than Performance Ford's kit last time I checked... When I have some extra $$ I'm getting the Perf. unit..
Posts: 1,028 |
I had the SMA torque Brace. Solid piece of metal that replaced the Stab-o-Shoc. I didn't really see any benefit to it, other than inducing more NVH in the pedals. Oh yeah, with 1.5yrs on it, its about to break. the OE part has been reinstalled and the annoying harshness is gone.  I say go Stab-O-Shoc, plus, the rigidity puts an extra load on the rest of the roll restrictors.
Chris NJ 98.5 SVT Silver Frost w/Frankentrans carsla AT optonline DOT net
Posts: 852 |
Yes, I am a bit weary of trying a solid mount solution... Anyone ever hold the stock stab-o-shock in their hands? I`d like to have an idea of the length and damping this thing has...Who says you can`t replace it with an el cheapo gabriel strut from a small car? Pending the length issue, of course...
Posts: 1,428 |
Marco, Swing by on Saturday, my car's gonna be on the lift at the place up in Laval. You can take a good look at it then, even take it off if you want to measure it... ..I need first dibs if you come out with an alternative!
Posts: 852 |
Cool. I can take a look at those brackets while I am at it...
Posts: 1,028 |
I'll take a pic of the SMA piece, uninstalled of course, this weekend.
