Page 2 of 2 1 2
N
N
oddball question since I'm getting one of these very soon. Can you remove the reverse lock out mechanism on the B&M or is it a part of the lever? I have the stock mechanism totally removed from my stock shifter and would like to keep it that way with the B&M if possible.
~Shawn Clone~
1999 SE Sport V6 MTX
Silver frost/Midnight Blue
BAT Euro Handling kit, SCA Cold Air intake, painted dash/calipers, Elky's mesh grille, bulitt fuel door,B&M shifter, ES motor mount inserts, OMP front strut tower brace, newest mod- HPP rear strut tower brace ...coming soon, Aussie Bar
Possabilities in the works: Custom CAI, Polished stainless shifter cover plate
Easy, don't reinstall the cast lug on the rear, passenger side retaining screw.
AL
Red '98 SVT E0 3098/6535
KKM, Elizabethan EGR Plate, TH fix
OMP front brace
Hightower rear brace
DMD
B&M with reverse lockout disabled and centering spring removed
Mobil 1 oil and trans fluid
A6 Side Markers, Optima orange, Horn recontent
Painted Sail Panels
VooDoo Knob and pedals, RogerR deadpedal
Blau Houston & CD changer
Cup holders that work
Donnelly mirror
BAT Sill Plates
and a Bullitt fuel door
I have the lockout tower installed on my E0 and it does't actually require me to use the pull-up collar to get into reverse. It does prevent me from dropping into R from 5 by accident. Works just like I want it to. Wierd, but I'm not complaining. And I can run the boot up to the base of the shift knob.
N
N
Can you remove the lockout collar completely or just not put it on? And what does the shaft look like without it?
~Shawn Clone~
Page 2 of 2 1 2
