Page 3 of 5 1 2 3 4 5
W
W
The problem was the first batch of shafts were the wrong grade of metal and were improperly heat treated. Once Vortech became aware of the problem they stopped production of the kit and found a new supplier for the shafts. (those of us who were the first warranty victims saw this first hand when it took months to get our replacement parts)
The leaky seals were caused by two major factors.
1- most people do not put a "loop" int the oil feed line causing a dry start condition, a loop in the line will hold oil after the engine is turned off so the SC will immediatly have oil upon start up.
2- oil temp. if you are on the highway or open road and moving its not a problem, but if you are someone who drives in heavy traffic a great deal then it becomes a major problem. for those constantly in traffic the ideal fix is to add an inline oil cooler to the line and still maintaining the loop. this will help out a great deal.
-Mark
You can do something for Love...
You can do something for Money...
But there is nothing quite so satisfying as doing something out of Spite.
GTExtreme1@aol.com
Originally posted by KnuKonceptz:
Anytime I do call Vortech I do speak with someone of decent knowledge and are sincere in trying to help me. They wont however replace my shaft till it goes bad (wont be long now), they even rejected my plead to purchase it and exchange for a slight discount. (they want over $500 for that shaft assembly)
So *make* the shaft go bad then... I know you've got a bad one since I ordered the kit the month that it came out... It was only installed 2-3 months tops and never had a chance to go bad on my car and has been sitting around since I sold it to you. Send it back to them to take a look at, give them the kit serial number... something...
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
-Mark
Wow thanks! The loop in the oil line seems sort of "rigged" but still works I guess. No traffic for me but would a oil cooler on my non-svt still help a tiny bit, I guess I don't know how much oil circulation that line going to the blower gets, it seems very small. Thanks!
2000 Roush Cougar MTX
MSDS Headers, Rear disc conversion, SVT TB and IM, Custom 2.5" exhaust, Weapon R Dragon w/kkm MAF adaptor, B&M, NR wht gauges
W
W
actually its common and it should have been included in their instruction manual. The reason for it is because it prevents all of the oil from draining out through the gravity fed drain to the pan.
-Mark
GTExtreme1@aol.com
Originally posted by bnoon:
So [b]*make* the shaft go bad then... [/b]
That was/is the game plan wink
Just got my SC kit today. Should have it on in the next couple of weeks.
Are you sure the Vortech now works on all SVT's?
I was told by Vortech that my later SVT had the
fuel system issue and they couldn't program around
the PATS and fuel cut off issues in the CPU...he
also said they weren't going to pursue the issue
further, and this was only back in January...
1999 Black SVT #2639/2760 on 08/11/1999; w/18" OZ Racing Superleggera's, Yoko Paradas.
MSDS Headers,Quaife LSD, Borla,KKM,chipped,DMD,Baer 13" Track rotors.
Lowered/HR and Koni's; HPP RSB
Dan, given your build date and vehicle number, I would guess that you have a returnless system. According to the included instructions, there is a section for returnless systems (page 8) that shows the addition of Vortech supplied fuel injectors. As far as the ECU, its a matter of installing the jumper, just the same way when installing a Diablo or Superchip. I had to send my ECU back to Vortech and I found out that my chip will most likely be a Superchip. I don't have the issues that you do since mine is a 98.5 SVT.
I
I
all is well running at 100%
-Mark
I would be VERY scared when someone tells me their car is running well at 100% laugh
99 Range Rover 4.6 HSE
Mystery Car??????
so you guys are saying that the Vortech S/C will work with the returnless fuel system. Does that mean it will work on my 95 SE? If it does, I'm getting one cuz i just got a deal on a new one for $4200CND. I just want to know if i should get it before deal is gone.
95 SE MTX Midnight Red
Dual Extrude Honed SVT Intake Manifold / 65mm TB / SC Cold Air Induction / Ford Racing 9mm Plug Wires / Quaife Limited Slip Differential / Centerforce Dual Friction Clutch / Fidanza Flywheel / UR Underdrive Pulley / Custom Dual Straight Flow Exhaust / StreetGlow Sport Pedals / Tint / Pioneer Deck and CD Changer / 2 12" Orion XTR subs / 2 MTX amps(425&280watts) / Phoenix Gold Titanium Bass Cube and Wiring / Boston Acoustic 5x7's, and Rockford Fosgate Tweeters. Next: 19# injectors and chip
Rebuilt engine @180,000 km
Rebuilt tranny @215,000 km
