Page 1 of 4 1 2 3 4
Corey Offline OP
hows everyones blowers doing?????
any more failures?
Mark, is yours still leaking or did you send that one out too?? any word from vortech, on whether they are gonna step up to the plate on this matter, or not??????
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
F
F
Mines running great, for now.
Speed kills, but it beats going slow!
Simon Langley
Black 98 SVT EO (#2119 of 6535)
269.3 FWHP, 195.4 TQ
14.123 @ 97.36
All go, and no show!
Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust.
CDW-27 1/4 Mile Registry
It appears mine is leaking. I had such a bad leak at the oil pan, I couldn't spot the other leak. Either I have a leak at an oil clamp, or my seals are gone. I get a little puddle right about the middle at the front of the motor.
98.5 SVT, Vortech SC, Bassani, Quaiffe, Clutchmasters Stg. 3, BAT Sport Springs/Konis, 17" Momo Arrows, Sparco Brace,BAT 22mm Sway Bar, PIAA fogs & headlights.
F
F
Is it leaking where the flexible part of the drain line clamps to the hard line running into the oil pan. It could be that or maybe your oil filter. Just making some suggestions.
If the seals were gone, the banjo fitting on the inlet of the supercharger would be full of oil. You may want to check that just in case as well.
Simon Langley
14.123 @ 97.36
Just pulled the intake to the banjo and the intake from the SC to the throttle body. GOOD NEWS!!! NO OIL!!! So, my seals are still intact. I should get my gauges some time next week. Then we will be able to tune this baby right, so I can get the kind of numbers you are getting fast4dr.
I have not been able to make any hp with this baby. The first chip didn't work. The next missed badly above 4500 rpm. The last has no miss and no hp. Once we know what the boost and fuel pressures are we can figure a few things out.
I will keep you all posted.
Jim
Corey Offline OP
not to rain on your parade but your seals will leak, just give them time
i used to think i would be the lucky one, but mine **** the bed too frown
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
2001 GSXR-1000
One more question. When the bearings on the jack shaft go what were the symptoms and indications? I just want to know what to expect.
Jim
Jim-
I am fortunate to not have this experience. I believe though if your shaft goes then it will go all at once.
I havnt got my supercharger back from Vortech but it will hardly ever see boost again. This is going to be my baby.
Sam
1998 Contour SVT #180
1/4=14.2 @ 101.17MPH
AOL users = PhatSVT
_ _ _____________ _ _
1986 Mustang GT
12 second club
W
W
Leaking oil... noticed the leak from the banjo at 2900 miles on the new SC.
I have been on the phone w/ Vortech on a regular basis to come up with a solution and they have asured me that it will be taken care of.
-Mark
You can do something for Love...
You can do something for Money...
But there is nothing quite so satisfying as doing something out of Spite.
GTExtreme1@aol.com
Corey Offline OP
-Mark
i still dont have the blower out of my car yet to send out.....hopefully vortech gets everything straight before i finally send mine along..... :rolleyes:
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
2001 GSXR-1000
Page 1 of 4 1 2 3 4
