Ok, here goes.
This is not a matter of not having enough exhaust energy to run the turbo. You, I, we don't know that, unless you ask the person that was doing the dyno.
uh, huh, sure.
But, there is a threshold that turbo needs to get up to spool and before that threshold a turbo will generate a of boost exponentially to its input.
Boost threshold is the point at which (in a given application) there is enough exhaust energy to spin the turbine at a speed to begin generating a useful amount of positive pressure in the intake tract, ie the turbo "spools up".
but before that a turbo will not simply sit there not create any boost
Yeah, because there isn't enough exhaust energy to spin it fast enough! c'mon this isn't rocket science.
and make the engine not have any power.
Well, this completely depends on how much power the engine makes without the positive intake air pressure. Some make a decent amount before additional pressure is applied to the intake tract.
Maybe if you run something like 6-7:1 CR, the low compression is going to make the car powerless until the turbo spools.
Yeah, but if you size the turbo properly, you don't have to wait very long, especially not to over 4k rpm!
But its a stock 2.5L V6 engine, a 6-7:1 CR would have much less horsepower so it can't be that and if it was at WOT you would have seen a power curve similar to one looks like without a turbo.
Dyno plots of forced induction (and even between turbo and s/c) and naturally aspirated engines are usually very different and distinctive, often enough so that a skilled eye can determine the type of induction merely by the shape of the graph. Oh, and in reference to a low CR and the power curve of a turbocharged car, ask terry haines' what a properly sized turbo setup will do on a low CR zetec.
Here, take a look at this wild Supra...
Okay . . .
Look at the last dyno sheet, see that little flat line right before the the chart flys up and make tons of HP. Same thing, leave a car on the dyno and don't give it any gas you will get nothing but a flatline...
I see a little flat line that extends for, oh, 50 rpm MAYBE, easily explainable by any number of things, from a slow foot on the gas pedal to turbo lag, etc.
In the Siboney turbo contour dyno plot, I see roughly 500rpm worth of flat line.
Here's a theory and a little explanation of whats going on.
Whew, I was getting scared there for a minute that you were a little confused . . . oh wait, is it your theory? or is it an actual explanation?
In the red you see nothing but a flat line because the throttle has been closed, at that point the ECU has gone into a close loop mode and is starting to lean out as part of its standard programming .
So, uh, does your car typically increase rpms when the throttle is closed? Cuz mine doesn't, nor does any car I've ever been in. (though there have been a couple lawsuits in the past, somehting about "unintended acceleration" or something, but I doubt it applies here) I also dont know of a single intelligent calibrator that will let an a/f ratio go to
18:1 under
acceleration (trying running your car at 55mph and let go of the gas, you will see injectors and a/f ratio goto 0)
Well, duh, this is because the injectors SHUT OFF under no throttle deceleration.
The Yellow, its a common trick to run it really rich in the lower RPMs to get a turbo spooling. You can see this as it reaches 13:1 Its a bandaide but it works...
I'm not going to argue your "common trick" in and of itself, simply because I've never calibrated an engine for transient events in turbocharging (though I will say I really believe your logic to be incorrect here, excepting one small possibility, that I don't believe comes into play here anyway).
In the green the turbo is spooling and you adjust the A/F mixture to get the desired EGTs. If there was a tuning problems they usually show up as spikes or power dips, somtimes the dyno plot is a squiggly line which I don't really see.
1. The turbo is way too big if it isn't spooling till over 4400rpm and only being used to make 6 psi of manifold pressure.
2. I see significant tuning problems in that a/f curve. I see a very inadequately controlled a/f ratio; harmful to overall power production, and often to the engine itself, especially in the lean areas (the two large, breast shaped areas of the curve). If you want to see a better a/f curve, go look at the one on the last dyno on the Supra you so kindly linked us to earlier. It isn't perfect, but much better, and he is probably a little extra rich on his tune to compensate for a lower octane fuel than he should be running at that dynamic compression ratio.
Its a little phoenemon called starting to record the dyno before you give it gas.
If they aren't giving it gas, why in the world are the revs increasing? Its not a graph over time, its a graph over rpm. And don't say, "oh they were only giving it part throttle" because that is ridiculous (then again, so was the quality of constrution of that setup, and the choice of turbo, and the venting of the blowoff/compressor bypass valve to the atmosphere on MAF controlled car) why would you not want to record the entire rev range of operation? and why would you only give it part throttle? it'll take even longer to accelerate up to the start point at part throttle over WOT (unless serious tuning issues prevent WOT from being a good idea under 4400rpm which makes things even worse)
Yes, is you don't give your car WOT on a dyno you are not going to produce a power curve. It will be bland flat line line an electric motor. It makes a constant amount of TQ at all rpms.
Um, sure, perhaps you needed to pay a bit more attention in physics class, or this wouldn't make sense to you either.
