Administrator
Administrator
Posts: 4,527 |
Originally posted by livinsvt: Oh and Rara about the injectors shutting off with no throttle under accel I think it would stall, right? (maybe you meant slow down?if not explain please.) O ya were in Novi do you live or use to live. I said deceleration, that means slowing down. The injectors do kcik back in when it gets down to idle speeds to stabilize the idle (or they will kick back in if the throttle is opened) I live near Novi rd. and 9 mile, but I am in the process of buying a house in westland.
It's all about balance.
bcphillips@peoplepc.com
Posts: 1,682 |
Originally posted by Rara: Originally posted by livinsvt: [b]Oh and Rara about the injectors shutting off with no throttle under accel I think it would stall, right? (maybe you meant slow down?if not explain please.) O ya were in Novi do you live or use to live. I said deceleration, that means slowing down. The injectors do kcik back in when it gets down to idle speeds to stabilize the idle (or they will kick back in if the throttle is opened)
I live near Novi rd. and 9 mile, but I am in the process of buying a house in westland.[/b]nooooooooooooooooooo!!! lost another one to wasteland....
Posts: 2,166 |
Listen I'm not going argue with you about the dyno.
Would you be willing to put money were your mouth is?
I'm going to be using what you would call large turbo, I'd be willing to set it to 6 psi and dyno it. How much do you want to bet if I started the dyno at 2k instead of 4k that you will not see a flat line until 4k rpm?
Posts: 352 |
Hi, Question...Were the secondaries pinned open on the Siboney run? If not, it would make sense to me that, when the secondaries opened up the additional tract it "stalled" the turbo. Yes...No? ...Ed
2000 Silver Frost SVT #1625 14 Jan 2000 Dual Mode Dampener A/C switched K&N Dropin Magnecor
Posts: 2,166 |
You know, that might be something to look at. The MX6/Probe guys say that when they pin open the variable intake on the K series V6 engine turbos acutally spool faster. Originally posted by edorfox: Hi,
Yes...No?
...Ed
Posts: 7,329 |
Boosted car still running the secondaries??? I see a problem here...
Administrator
Administrator
Posts: 4,527 |
hmm, I really wish I had some time to cover this right now, but since I don't I will have to settle for asking a few questions.
1. What exhaust a/r do you plan to use on you 60 trim T04E?
2. Do you plan on intercooling? if so what method, and size of IC are you planning on?
3. How does an engine increase rpm on the dyno with no throttle application?
4. Why would anyone not want a complete dyno pull? (ie why not get the complete pull when you have to accelerate through the lower rpm anyway)
5. If peak power isn't your main concern (otherwise you would be beefing things up, etc.) why wouldn't you consider a turbo that would be better compromise of efficiency between the 2 levels you plan on running?
Posts: 2,166 |
Originally posted by Rara: hmm, I really wish I had some time to cover this right now, but since I don't I will have to settle for asking a few questions.
O-trim .69
Front mount, I'll have to measure it and get back. FWIW is a custom Starion IC
No resistance being put upon power output from an inertia measured dyno when throttle is held constantly
Trying sticking your car in 5th, apply a constant amount of throttle (not WOT) the car will slow reach its terminal speed when wind resistance overcomes power output
Like I stated before, cars with little torque in the low revs will take alot of time on the dyno. Starting at a higher rpm will put the engine in the power band thus taking less time. Its also a possibility he was having tuning issues. But I spoke with them on the phone and he said its running fine. I didn't bother to ask him about the dyno.
A T4e can run 400-450hp effectively A T3 60-1 can run 300-350hp effectively A T28...
I really want a HKS 3037 but its $2640 So I have to settle with a T4e thats going to cost about $1500. A T3/T4 would probably run me $1100
Its possible a T3/T4 hybrid would be the best for my setup and even a little cheaper. But the Duratec likes to breathe, should I go with a smaller turbine it would generate more unwanted heat from an elevated backpressure ratio and less power.
Plus I've worked T4s in the past on smaller 2.0L 4cyl (SR20DETs if there are any Nissan owners out there) engines with no spooling problems. And now with ball-bearings center sections they look even more promsing.
Are we still on for the bet?
Posts: 443 |
Originally posted by DemonSVT: Boosted car still running the secondaries???
I see a problem here... The 4G63 Mitsubishi engine in Japan spec set up uses secondary throttles just like the Duratec. However the US version has the secondary's removed.
Administrator
Administrator
Posts: 4,527 |
I'm not ignoring this, I just haven't had time to put together a cohesive response. I'm in the middle of a "new" vehicle launch at work, and the hours have been rather long lately (and fwiw, yes it is a forced induction vehicle)
