Page 6 of 6 1 2 3 4 5 6
#406968 06/01/02 03:56 AM
F
F
Can't think of a better reason to see if the Escape/Tribute 3.0 will work for the swap laugh
TruckPerformance.com Kenne Bell Supercharger for the 3.0 Escape/Tribute
Best Regards,
Trevor Cole
New Edge Cougar Forums
#406969 06/04/02 01:32 PM
F
F
Best Regards,
Trevor Cole
#406970 06/05/02 12:43 AM
Yes you could put a whipple supercharger on just about any car, However if you are talking about puting Kenne Bell's kit for the Escape on a Contour or Cougar there would be very little of the parts in the kit that you could use on the Contour or Cougar besides the Whipplecharger itself. You would be better off buying a Whipplecharger and making your own kit, because that is basicly what you would be doing by buying the Kenne Bell kit and not getting to use most of the kit. smile
#406971 06/06/02 05:57 PM
F
F
Reread my post regarding the Kenne Bell ... it states paraphrased("a good reason to see if the Tribute/Escape 3.0 would swap directly in"). Notice that almost all 3.0 swaps have been done using the Taurus/Sable 3.0 and/or LS 3.0 ... nobody has tried the Escape/Tribute. If it does indeed bolt up (I'm sure hood clearance would an issue, but EASILY remedied), whala, instant aftermarket for 3.0 superchargers.
Best Regards,
Trevor Cole
#406972 06/06/02 06:03 PM
F
F
Originally posted by MCJT:
I bought a an LS engine from Terry. Think this would work on an LS conversion?
Here is the link: http://www.specialvehicles.com/ls/blower.gallery.htm
This is the V8. I called them today about the 3.0 and they said they didn't have one done yet and are currently casting plenums for the 3.0.
Transversly mounted, this application would have the TB pointing at the Firewall ... it would not b a direct fit and there would be plumbing issues with the intercooler they are running/appear to be running.
Best Regards,
Trevor Cole
#406973 06/16/02 03:53 AM
Actually,
after looking at the webpage, there doesnt appear to be an intercooler there, and if you are familiar with the Eaton, you can flip that intake portion of it 180 degrees to point to the front, or you could just mount a "fuelie" teardrop topp fueler hood scoop on it, and not worry about the hood clearance problems at all... wink
Or you could find a different place to mount the supercharger.... Hmmmm I wonder where......teeheeeheee laugh
Tony Blatnica
99 Contour SE-Sport 2.5ATX
SVT Exhaust - Removed resonator
TH-Fix
