I was with you for a while there Tom but now you are patting yourself on the back a little too much.
I dont know any one else that does there own tuning on these cars with turbos ,diablo and superchips CAN NOT do this,
Perhaps you did not know this but software for Diablo to be released to dyno's is just around the corner...temporarily you are correct.
and the afc and the msd is not the way to go,it is a bandaid fix and it may work but it is not the best way
that is why we got into doing our own custom ECU tuning
A chip is no better or worse than the other methods. The best solution is a whole new ecu but I agree with you that is very pricey. Both of these methods put a thin veil infront of the ecu and change info. The route you are using is not the be all end all.
Edited:
the 900.00 is for YES a set of 42lbs injectors recal.70mm mass air .and a chip that has been proven
Just out of curiousity how much do your chips cost? The maf and the injectors shouldn't be more than 300 that leaves 600 for a chip? I assume that your developement time was included in this price?
