#406680 02/18/02 04:47 AM
someone please help me out here. i need to know what nitrous kit to use on my car and if i can in fact use it im not sure what fuel system i have. someone please help me out. i have searched and still don't really know what to do.
99 se sport
hyper ram air intake
custom cold air box
2 1/4" catback
tsudo muffler
eibach lowering springs
hyper white lows & fogs
panasonic 801u head unit
memphis 5x7's
#406681 02/18/02 06:02 AM
i have a 98.5 svt and i put the ZEX NOS in my car my self it wasent to bad. I dont know if that helps you any but here is my e-mail if you have any questions.
playazprez@hotmail.com
#406682 02/19/02 05:57 PM
Well first off you'll run a dry nitrous set up. I'd recomend that you don't go over a 75 shot. The fuel systems are all the same I belive. But you'll need a rising rate fuel pressure regulator to keep from leaning out. Also get an air/fuel ratio guage so you can keep an eye on the air/fuel mix. Remember nitrous dosen't f*** up engines it is lean mixtures and stupid people who f*** up engines.
1999 Silver Frost ATX Mercury Mystique
Mods:
Throttle Hang Fix
Fog Lite Fix
Gutted Air Box
Sony Xplode Head Unit
215/60/15 Goodyears
Hyperwhite Low Beams (9006)
Castrol Syntec Oil (5W30)
#406683 02/19/02 07:09 PM
I
I
Get them Venom 2000 kit. The kit comes with on board monitoring of air/fuel. And if the fuel mixture ever goes dangerously lean, the system automatically disengages itself, so you dont damage your engine. Cost: $1200 but worth every bit of it!
99 Range Rover 4.6 HSE
Mystery Car??????
#406684 02/19/02 08:19 PM
You can't use a Zex kit if your car is a '99. Your fuel system is not compatible.
1991 GVR4
Lots of mods done.
#406685 02/19/02 10:17 PM
9
9
To get even more convoluted here, if the car is an EARLY 1999, then it will likely still have the RETURN style fuel system, which is required to run the ZEX kit. If you have a later 99, then never fear....Venom has a new kit called the VCN-1000 that interfaces with the fuel injectors to richen the fuel mix. It also interfaces with the o2 sensor to protect against rich/lean conditions. Cost? A little than the VCN-2000, the VCN-1000 will set you back about $650-$700, and you will still need good stuff like a gauge pod, rich lean indicator, bottle pressure gauge, and possibly a bottle warmer.
Former owner of 1999 SVT Contour #555
