Posts: 1,692 |
1tubofocus I bet you give me say 2 weeks of the way I drive my cars like I rent them and I will be blowing something up on it. and there is no way my 1996 Zetec with 56k on it would survive that kind of boost.
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 65 |
ZETECRACING im not saying that any moron cant blow up there engine if they tryed hell give it to me and ill do it in 10 min. any one want to go for 9 min.
what i am saying is that i have a turbo kit that is doing more hp than any one else has done yet on a stock engine ,it is still running ,it is a clean kit and looks good
as for terry blowing up an engine just to see it blow ,my first question is why,i would want to see how far i could get it to live to ,maby this is what he did and then it cut loose
as for the rest of you on here that want terrys kit ,hay good im glad that you feel like terry is the way you need to go and i would not want it any other way
all i am doing is offering a nother idea to think about
if mcdonalds was the only fast food to go to the wourld would suck
terry i do not have any pictures of my shop to send you we are a small shop outside of charlotte NC. we have a full machine shop and a dyno jet dyno in the back we are now looking for some property to build on
it is nothing fancy if that is what you are looking for,we are kinda messy with engine parts every where,
thanks tom
Posts: 569 |
Originally posted by 1turbofocus: as for terry blowing up an engine just to see it blow ,my first question is why,i would want to see how far i could get it to live to ,maby this is what he did and then it cut loose IIRC Thats what he was doing, seeing just how far they can go before they'll let go. Knowing it'll go at some point, just how far.
**Spelling should not count**
2000 SE Zetec ATX Medium Steel Blue (Now with large custom dent on the rear door) Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
Posts: 5,805 |
I take exception to your 'moron' terms old chap...the engine was in a dyno cell with increasing rates of boost,spark & fuel maps being run.The failure was at around 5500 rpm,max load,WOT...we made 325 BHP and the rod caps combined with the wrist pin bosses let go.This is why on the 350bhp unit we are going to custom rods with bushed wrist pin ends,custom pistons,piston cooling jets etc.I spent the first 4 years with Ford in Dunton,England in & around the dyno cells,I think I know how to run engine mapping and max load etc tests......
Posts: 522 |
Well, Terry. I'm still waiting for your duratec turbo, even though Chris Hightower put one out. Or I'll be throwing in a 3L over next winter.
A. Van 95 Eagle Talon TSI AWD 98 Contour SVT ( For Sale )
SVT/SHO Society Member
Posts: 2,481 |
as for terry blowing up an engine just to see it blow ,my first question is why,i would want to see how far i could get it to live to ,maby this is what he did and then it cut loose Someone doesn't understand FMEA's :rolleyes:
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 5,805 |
Spot on the money Mike.....!
Posts: 65 |
terry if you go above where i wrote the moron theme you will se ehere ZETECRACING wrote he could blow one up in 2 weeks
then i said any moron can blow up an engine,not terry,not zetecracing,just any moron,if any one on this board is a moron this is directed to you
i dont think you class yourself as a moron and neather do i
dang i havent been called an old chap in a long time
and yes we never know how much an engine will take ,but some of the guys on here make it sound like you blew it up just to blow it it,and this may be the case
tom
Posts: 650 |
Posted by 1TurboFocus ohsigmachi who said you have to run 18psi so you have 70.000 miles on your car so only run 10psi or 8 or 4 that is up to you and how you set your regulator
**Wow, I think you just one the award for slipperiest answer of all time.** What I was trying to spell out to you is this: **YOUR** 300+ horsepower 18psi $5200 Bolt-on Trubo kit will disinegrate most of the older stock Zetecs on this forum!! However Terry's kit be it however much more expensive will NOT. If I wanted to make 200+hp why would I buy buy your outrageously priced bolt-on and then dumb it down to 8-6 psi? I WANT TO MAKE 300HP!! Therefor I will have to go with a kit that will address the internal weakness of my older engine.
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper) Suffice it to say my mod list has become so long that it is just ridiculous
Posts: 65 |
hay i under stand like i have said before my kit is not for every one
here it is, this is what it can do ,and if you like it i will work with you all i can
if its not for you ,maby i can help with other stuff
tom
