Posts: 1,071 |
I've got a freind who is a boat mechanic, and he said that Mercruiser recommends using an "Extreme Pressure Spline Grease" in their outdrives. He thought that it might help. I am going to try that when I reinstall the blower.
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 2,915 |
Originally posted by PhatSVT:
HAHAHA! yeah exactly. I sure hope they are installing the S-trim for me. I called them today to see what the deal was and the phones are busy, so I am going to give it a try later. whats the difference between the two sam? besides just noise?
www.shox.com Dealer Koni's 135 a piece Eibach's 190 a set KYB's 70 a piece H+R's 225 a set see profile for website, aol name, etc Business:WestEndMobil@yahoo.com Personal:Corey_pimp1@yahoo.com 1998.5 SCSVT ($16000 takes it) 2001 GSXR-1000 1988 Corsica (the beater)
Posts: 124 |
What would the feasibility be of installing another supported bearing(say from a go-cart axle) closer to the supercharger when you get the new one from vortech? (shouldnt be too difficult to fab a bracket to house the bearing.. might need to put a fitting for a greasegun to lube it though.. simple maintenece should eliminate alot of headaches) This should help eliminate ALOT of the shaft wobble, thus non-treated splines would not be as much of an issue?
Tony Blatnica 99 Contour SE-Sport 2.5ATX SVT Exhaust - Removed resonator TH-Fix
Posts: 443 |
Originally posted by GoodwinToo: What would the feasibility be of installing another supported bearing(say from a go-cart axle) closer to the supercharger when you get the new one from vortech? (shouldnt be too difficult to fab a bracket to house the bearing.. might need to put a fitting for a greasegun to lube it though.. simple maintenece should eliminate alot of headaches) This should help eliminate ALOT of the shaft wobble, thus non-treated splines would not be as much of an issue? I could'nt agree with you more. That mod alone would increase the life of the blower significantly!!
Posts: 125 |
I have a Vortech SC, am in SoCal. Had lots of troubles with tuning. Finally had Vortech custom burn a chip. It is done and I get it back tomorrow. I'll let you all know about the results. I am concerned about the reliability thing though. I have less than 1000 miles on it. But I think I have the gold color shaft, which I believe is supposed to be better. I am interested in anything you all know about that.
Good luck to us all!
98.5 SVT, Vortech SC, Bassani, Quaiffe, Clutchmasters Stg. 3, BAT Sport Springs/Konis, 17" Momo Arrows, Sparco Brace,BAT 22mm Sway Bar, PIAA fogs & headlights.
Posts: 98 |
I don't think anyone has one on the cougar yet. Everyone is waiting for the turbo.
1999 V6 MTX Black Cougar
Jacobs ignition system, Borla dual exhaust, Sho shop y pipe and hi flow cat, gutted precats with MIL eliminators, IAT rewire, vitek ignition wires, SCA CAI with monster flow filter, Unorthodox racing pulley, BAT rear strut brace, Battery relocation to trunk, eibachs, KVR crossdrilled/slotted rotors, freedom design strut brace and Tuned S-AFC
Waiting to be installed: svt engine with 11k miles on it/ fidanza flywheel/Quaife/energy suspension engine mount inserts.
Posts: 124 |
Jim(et al), Ive been doing some looking into this for you...Even if you have a hardened shaft I would mount a bearing. Depending upon the diameter of the shaft, I would fabricate a bracket to hold a bearing on the jackshaft right along next to the Supercharger(about 8-10 inches away from the supercharger..more or less depending upon where you can mount the bracket too). I found this place: Axle Bearings that seems to have good priced and a multitude of axle bearings.(they even have live axle bearing mounting kits you could probably make work) Now you could use the perfrmance sealed version mounted into a flat plate of 3/8 stock aluminum(cut to shape for your bracket and mounted to somwhere along the head, intake manifold, water pump assembly, or wherever) with whichever size OD hole needed for the bearing, cut into it... To fasten it, just machine the hole with a postive lip in the hole(similar to how you would a sleeve for a bore on an engine block) then tap it in with a little bit of loctite and countersink through the 3/8 stock a set screw, and you should be good to go... That should eliminate shaft wobble for .. hmmmm around $15-50 bucks, depending on the size of your aluminum sheet and if you can cut it yourself(and if you have any lying around). Good luck!!
Posts: 2,708 |
Tony, No offense because what you are saying is sound and a good idea, BUT have you seen the Vortech drive up close? I doubt you have because you would see just how hard it would be to adapt your idea to the existing setup.
-Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 443 |
Originally posted by WorldTour: Tony, No offense because what you are saying is sound and a good idea, BUT have you seen the Vortech drive up close? I doubt you have because you would see just how hard it would be to adapt your idea to the existing setup.
-Mark Well I have seen it and I say it can be done. Why doesnt someone post some good clear closeup pictures of everything setting where it should be when installed. That way some of us guy's that have experiance making brackets and supports of this type could help you guy's with the SC work your problems out. I know that I for one would love to help you out, if we can come up with a spot to mount the bracket and the dimensions for it I would be happy to make the bracket for you[NO CHARGE OF COURSE] If we could work together we can work it out!
Posts: 125 |
I will try to get some pics of the shaft and the general mounting areas. My problem is I am no mechanic, All that stuff Tony says should be simple to do....Well, it's Greek to me.
Jim
