Posts: 197 |
What spark plugs should I use when I install the Zex? I have a set of Bosch Platinums that I haven't put in yet, would those be OK? Maybe you can help me Neil. Thanks Guys!!
Former Owner--98 T-Red SVT
Current Owner-- 2002 VW GTI 1.8T--5 Speed-Reflex Silver-Black Leather
87 S-10 Blazer 4x4(Winter Ride)
Posts: 2,156 |
cheap plugs= Autolites
good plugs= NGK TR55 or TR6
remember don't use Platinum plugs.
Sam 1998 Contour SVT #180 1/4=14.2 @ 101.17MPH
AOL users = PhatSVT _ _ _____________ _ _
1986 Mustang GT 12 second club
Posts: 4,319 |
1991 GVR4 Lots of mods done.
Posts: 2,708 |
Stick with the NGK's. They have a much better track record then Autolite's, Accel's, Champion's, etc...
-Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 2,156 |
I just noticed you are runnen Khumho Ecsta's. You might want to by some other tread cause once you hit that N2O2 those tires of yours will go up in smoke. Neil had some good tread on his Contour but those of his even said "f*** you!" just trying to let you know you are going to be given the crowd more of a show then anything else with your tires going up like fourth of July.
Posts: 197 |
Originally posted by PhatSVT: I just noticed you are runnen Khumho Ecsta's. You might want to by some other tread cause once you hit that N2O2 those tires of yours will go up in smoke. Neil had some good tread on his Contour but those of his even said "f*** you!" just trying to let you know you are going to be given the crowd more of a show then anything else with your tires going up like fourth of July. Yeah the Kumhos are all done anyways. They have about 35,000-40,000 miles of hard driving on them. And the two Contours they were on have been lowered which didn't help. Neil, what tires were you running? Any suggestions?Nitto, Toyo,Yoko?
Posts: 4,319 |
KDW's all the way......
I run Yokohama Paradas and they go up in flames.
Posts: 1,217 |
remember don't use Platinum plugs. NGK TR55-Vx are Platinum..........
Posts: 2,156 |
i have NGK TR55 and no where on it does it say Platinum. are the ones your thinking about say Platinum anywhere?
Posts: 7,329 |
Originally posted by Trapps:
NGK TR55-Vx are Platinum.......... Yes they are. However TR55's are not. Notice the lack of the VX suffix...
