Posts: 5,805 |
Tom, to take spark out dont you need a MAP sensor?,this is the reason for my question,the EEC drivers/calibration's dont support a MAP input....
Posts: 1,173 |
Great Stuff! I feel like I'm at a Turbo Roundtable or something! And I don't understand 80% of it!!
Sal Khan
'00 Silver SVT - KKM, SMA Torque brace.
'00.5 Aprilia RSV Mille - Renegade 2-2 Exhaust, Renegade Air Kit, lots of chips, Evoluzione Ignition Amp, 44t Rear Sprocket
Want to see what I did for lunch today? Check out http://www.mindspring.com/~salk/Lunch/LunchJournal.html !!!
Posts: 65 |
terry at our dyno jet dyno we have the software and a program to do chips for the JFA8 focus code so we do our own custom chips,fuel and timing maps and we just use the maf and the o2 just like the stock computer does
the JFA8 is the only code we have done so far that is what my car is ,we are now doing some others now
tom
Posts: 5,805 |
So spark & fuel are only depeandant on MAF,TPS & 02 inputs?...what happens when you crank up the boost? how does the CPU know to alter fuel & spark ?
Posts: 65 |
as i said earler all the tables are set up on load vs rpm and most of this comes from the mass air
as you up the boost you pull more air through the mass air ,the computer reads this and adds more fuel and takes out timing as we told it to do through the chip
just like the computer was ment to work from the factory the extra fuel comes from the 42lbs injectors and knowing how to controle them,for 300 at the wheel hp you realy need the 52lbs im hitting 100%injector duty cycle at 4800rpm
its quite simple realy,once you see it work
tom
Posts: 5,805 |
Tom, could you comment on the attached as I think this has slightly more info,just interested.Thanks TH www.Pectelusa.com/new_products.html
Posts: 65 |
i have nothing agenst the pectal but the price
the t2 is to small to carry 300fwhp on the focus because it cant run low imp.injectors if you are only going for about 270fwhp it will do ok you will still need larger injectors and tuning through a mass air is much easier and we have found more hp over the map many times
so to do a safe 300+ hp you would need the t6 at 2 times the money
and the car allready has a computer that can do the job
my way 2.0 zetec injectors 42lbs or 52 lbs (250.00) 70mm ported mass air set for 42or 52`s injectors high imp. (200.00) driver installed in the stock computer to run the low imp. injectors (200.00) custom chip with dyno time if needed (650.00)
200hp to 270fwhp==1100.00 300+ hp==1300.00
pectay way t2 or t6 (3000.00 to 5000.00) i think injectors (250.00) dyno time (200.00 to 500.00)3 to 5 hrs minimum cost (3500.00 to 5500.00)
and not every can program the pectal,i know guys that have spent 20+ hrs on the dyno to try and get there car to run right on stand alone units ours is plug and play
terry what is the price of a t2 and t6 just to be fair
just my thoughts tom
Posts: 604 |
WOW, this is a great mature dicussion. Its great to see what the internals for a "kit" are like. The parts are one thing but the design and testing are another....and whats this about a meet Simon....tell me we had a meet and I wasn't invited!!! :p
"The thing from which the work suffers more than from any other evil is not the assertion of falsehood, but the endless and irrepressible repetition of half-truths." – G.K. Chesterton
Posts: 650 |
If you want something done hand it to a busy man... That is quite possibly the best Sig I've ever seen.
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper) Suffice it to say my mod list has become so long that it is just ridiculous
Posts: 1,071 |
Originally posted by GHBBF1: WOW, this is a great mature dicussion. Its great to see what the internals for a "kit" are like. The parts are one thing but the design and testing are another....and whats this about a meet Simon....tell me we had a meet and I wasn't invited!!!
:p Sorry :rolleyes: It was posted on the focaljet. Didn't realize you would have made the treck up to Charlotte. All you missed is me getting my ass wooped by a focus  I'll let you know about the next one
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
