Page 3 of 7 1 2 3 4 5 6 7
#406014 01/12/02 10:40 PM
Originally posted by E1SVT:
coNNiethecoNTour wrote:
"If you need a car for a demo......Ill offer MIne.....and I was the first one to offer I hope "
Are you going to be at SZ2002?
I plan on but im not sure when my finals are yet.....
-Mancho- cars name is Connie
99 Silver Frost SVT #1986
k&n filter with cut out box
true duals w/ flows smile
Ground Controls with 17's mille miglia ...
Hightower headlights
15.4 at 90.29 at Milan dragway before the true duals smile
#406015 01/13/02 01:19 AM
9
9
Can someone tell me why a turbo is better than as s/c? Esp if it cost a lot more. A s/c gives u more power all the time....
at 500rpm's, at7500 rpm's etc. A turbo only kicks in around 3000 rpm's. I'd just like to know what the advantages are to a turbo, I hear they are a lot of work and have a lot of little stuff go wrong compared to a s/c, but i don't know much about turbo's so can u tell me why this is good?
99 Tropic green svt
Custom Stereo
borla cat-back
22mm bat rear sway bar
custom K&N & heatshield
215/40/ZR17 Rubber
jimmkreider@yahoo.com
#406016 01/13/02 01:55 AM
How much of a down payment do I need???
Jose 97
Jose 97
97 SE T-Red 24V MTX built 4/96 Mods LOTS!!!
#406017 01/14/02 03:00 AM
99BADSVT here ya go, it's for a mustang but you get the idea... Turbo vs SC
Originally posted by 99SESPORT:
First off, if somebody is grabbing your nuts, your gonna do everything you can to get him off...
And sitting there telling him politely
"Please let go of my nuts, sir?"
#406018 01/14/02 03:08 AM
F
F
Not exactly. A blowers boost, especially centrifugal, depends on engine RPM. A turbo, will be able to attain full boost all throught he RPM range...as long as the exhaust volume is enough. Also the supercharger uses alot of engine power to drive it, while the Turbo just adds a little backpressure to the exhaust.
The Vortech for the Duratec only reaches its max boost (9 psi) at redline, and only starts building boost around 2500-3000 rpm. I get 1 psi at 2500, 3 psi at about 4000, 5 psi at about 5000, 7 psi at about 6000, and full boost at redline. A turbo should create more boost at lower rpms.
Speed kills, but it beats going slow!
Simon Langley
Black 98 SVT EO (#2119 of 6535)
269.3 FWHP, 195.4 TQ
14.123 @ 97.36
All go, and no show!
Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust.
CDW-27 1/4 Mile Registry
#406019 01/14/02 03:39 AM
and some ppls are even worse than that.......a certain person i know wink , his sc'd svt doesnt build boost till about 4000-4500 rpms.....and only gets 6 psi at redline.....
get the damn turbo..... laugh
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
#406020 01/14/02 03:52 AM
W
W
You know I am interested Chris, but I have two issues. Will it be warrantied on the 3l, assuming the compression ratio is comparable to stock or an svt? I am running 10.3:1, essentially the same as the 2000 SVT.
Is the turbo going to be big enough for the motor?
Other than that I am hell interested, but about tapped out on large amounts of cash for a little while.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
#406021 01/16/02 03:31 AM
W
W
Well, Chris?
I was hoping you'd have some info for us 3L owners out here.
Take your time though, no rush.... wink
warmonger
Engine: 3.0 power!
Check them out at
#406022 01/16/02 05:33 PM
I would like to chime in on this one. The turbo will be a much better kit for one simple reason. NO JACKSHAFT!!!
2001 Mercury Cougar
Aerogear WideBody Kit, Aerogear Carbon Fiber Hood
3.0 Hybrid 251hp and 229tq at the front wheels
Eibach springs, Koni Stuts, Aussie Bar, ST200 R Strut bar, OMP front Strut bar, 19" RPM's 235/35-19 Nitto 555's
All Alpine System - IVA-C801, DHA-s680, NVE-N852A, TCS-V430A, TMX-R705, TME-M580 x2, PXA-H900, MRD-M500 x2, MRV-f540 x2, SPS-0829, SPX-F17t, SPX-17m x2, SWR-1021D x4, RUX-4280
http://www.geocities.com/socal_neco/jimmy.htm
#406023 01/16/02 07:00 PM
Administrator
Administrator
Well, for starters:
-The turbo will make good boost around 2300RPM.
-The Duratec doesn't start making power till around 3200 (good power anyway)
-The turbo only has ONE moving part aside from the wastegate.
-Oh, and no jackshaft.
Warmonger, the turbo will work with your 3L. Same heads, same everything. The fact that your comp ratio is .05 more than the 2000 SVT isn't anything to worry about. I'll have to make a new flow chart for the 181 cubic inches worth of motor, but I can guess 6-7PSI could be obtained with the T28 we are using. I'm sure we will find out soon enough. smile
-Chris
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
