Posts: 581 |
Originally posted by E1SVT: ------------------------------------------------------------------------------------------------ coNNiethecoNTour wrote: "If you need a car for a demo......Ill offer MIne.....and I was the first one to offer I hope " ------------------------------------------------------------------------------------------------
Are you going to be at SZ2002? I plan on but im not sure when my finals are yet.....
-Mancho- cars name is Connie 99 Silver Frost SVT #1986 k&n filter with cut out box true duals w/ flows  Ground Controls with 17's mille miglia ... Hightower headlights 15.4 at 90.29 at Milan dragway before the true duals
Posts: 411 |
Can someone tell me why a turbo is better than as s/c? Esp if it cost a lot more. A s/c gives u more power all the time.... at 500rpm's, at7500 rpm's etc. A turbo only kicks in around 3000 rpm's. I'd just like to know what the advantages are to a turbo, I hear they are a lot of work and have a lot of little stuff go wrong compared to a s/c, but i don't know much about turbo's so can u tell me why this is good?
99 Tropic green svt Custom Stereo borla cat-back 22mm bat rear sway bar custom K&N & heatshield 215/40/ZR17 Rubber jimmkreider@yahoo.com
Posts: 525 |
How much of a down payment do I need???
Jose 97
Jose 97
97 SE T-Red 24V MTX built 4/96 Mods LOTS!!!
Posts: 704 |
99BADSVT here ya go, it's for a mustang but you get the idea... Turbo vs SC
Originally posted by 99SESPORT: First off, if somebody is grabbing your nuts, your gonna do everything you can to get him off... And sitting there telling him politely
"Please let go of my nuts, sir?"
Posts: 1,071 |
Originally posted by 99badsvt: Can someone tell me why a turbo is better than as s/c? Esp if it cost a lot more. A s/c gives u more power all the time.... at 500rpm's, at7500 rpm's etc. A turbo only kicks in around 3000 rpm's. I'd just like to know what the advantages are to a turbo, I hear they are a lot of work and have a lot of little stuff go wrong compared to a s/c, but i don't know much about turbo's so can u tell me why this is good? Not exactly. A blowers boost, especially centrifugal, depends on engine RPM. A turbo, will be able to attain full boost all throught he RPM range...as long as the exhaust volume is enough. Also the supercharger uses alot of engine power to drive it, while the Turbo just adds a little backpressure to the exhaust. The Vortech for the Duratec only reaches its max boost (9 psi) at redline, and only starts building boost around 2500-3000 rpm. I get 1 psi at 2500, 3 psi at about 4000, 5 psi at about 5000, 7 psi at about 6000, and full boost at redline. A turbo should create more boost at lower rpms.
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 2,915 |
Originally posted by fst4dr: The Vortech for the Duratec only reaches its max boost (9 psi) at redline, and only starts building boost around 2500-3000 rpm. I get 1 psi at 2500, 3 psi at about 4000, 5 psi at about 5000, 7 psi at about 6000, and full boost at redline. A turbo should create more boost at lower rpms. and some ppls are even worse than that.......a certain person i know  , his sc'd svt doesnt build boost till about 4000-4500 rpms.....and only gets 6 psi at redline..... get the damn turbo.....
www.shox.com Dealer Koni's 135 a piece Eibach's 190 a set KYB's 70 a piece H+R's 225 a set see profile for website, aol name, etc Business:WestEndMobil@yahoo.com Personal:Corey_pimp1@yahoo.com 1998.5 SCSVT ($16000 takes it) 2001 GSXR-1000 1988 Corsica (the beater)
Posts: 1,050 |
You know I am interested Chris, but I have two issues. Will it be warrantied on the 3l, assuming the compression ratio is comparable to stock or an svt? I am running 10.3:1, essentially the same as the 2000 SVT.
Is the turbo going to be big enough for the motor?
Other than that I am hell interested, but about tapped out on large amounts of cash for a little while.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted) 99 Silver Frost SVT. #226 of 2760 Engine: 3.0 power! Unique Stuff: Sunroof control module (#1 of 9) Car Audio: Loaded and loud! Check them out at http://home.earthlink.net/~twilson1726
Posts: 1,050 |
Well, Chris? I was hoping you'd have some info for us 3L owners out here. Take your time though, no rush.... warmonger
Posts: 154 |
Can someone tell me why a turbo is better than as s/c? Esp if it cost a lot more. A s/c gives u more power all the time.... at 500rpm's, at7500 rpm's etc. A turbo only kicks in around 3000 rpm's. I'd just like to know what the advantages are to a turbo, I hear they are a lot of work and have a lot of little stuff go wrong compared to a s/c, but i don't know much about turbo's so can u tell me why this is good? I would like to chime in on this one. The turbo will be a much better kit for one simple reason. NO JACKSHAFT!!!
2001 Mercury Cougar Aerogear WideBody Kit, Aerogear Carbon Fiber Hood 3.0 Hybrid 251hp and 229tq at the front wheels Eibach springs, Koni Stuts, Aussie Bar, ST200 R Strut bar, OMP front Strut bar, 19" RPM's 235/35-19 Nitto 555's All Alpine System - IVA-C801, DHA-s680, NVE-N852A, TCS-V430A, TMX-R705, TME-M580 x2, PXA-H900, MRD-M500 x2, MRV-f540 x2, SPS-0829, SPX-F17t, SPX-17m x2, SWR-1021D x4, RUX-4280 http://www.geocities.com/socal_neco/jimmy.htm
Administrator
Administrator
Posts: 5,037 |
Originally posted by 99badsvt: Can someone tell me why a turbo is better than as s/c? Esp if it cost a lot more. A s/c gives u more power all the time.... at 500rpm's, at7500 rpm's etc. A turbo only kicks in around 3000 rpm's. I'd just like to know what the advantages are to a turbo, I hear they are a lot of work and have a lot of little stuff go wrong compared to a s/c, but i don't know much about turbo's so can u tell me why this is good? Well, for starters: -The turbo will make good boost around 2300RPM. -The Duratec doesn't start making power till around 3200 (good power anyway) -The turbo only has ONE moving part aside from the wastegate. -Oh, and no jackshaft. Warmonger, the turbo will work with your 3L. Same heads, same everything. The fact that your comp ratio is .05 more than the 2000 SVT isn't anything to worry about. I'll have to make a new flow chart for the 181 cubic inches worth of motor, but I can guess 6-7PSI could be obtained with the T28 we are using. I'm sure we will find out soon enough. -Chris
