Posts: 1,225 |
Don't know if any of you are interested, but I e-mailed NOS (Holley) today about the direct injection kit. Basically I asked for some simple dimesions and took a shot in the dark and asked about duratec fitment. I'll let you know what they say when they return my e-mail.
Ryan
Latest Mod: Mirko Splitter
Posts: 1,225 |
Well here is the beautifully in-depth answer from NOS..... The injectors and fuel rails will be raised about 1 inch.
Thanks, NOS tech dept.
So I guess someone will have to be the guinea pig and see what happens...
Ryan
Posts: 613 |
well I tell you what. If you guys buy the system Ill go ahead and be the ghuinea pig, lol
~~~~~~~~TRAVIS~~~~~~~~ Now driving: I MEAN NOT DRIVING---- 1995 Contour SE Maroon, MTX, sunroof w/rain-guard, neons, and audio replaced. Side Markers installed and headlight strobes also now on. *KKM tru-rev - I love it 9mm FMS blue wires SVT Upper SVT exhaust SUPERCHIP² custom ram air Newest mod = f***ed up engine, prolly shot, yeah
Posts: 446 |
The top of the fuel rail will be a problem. Angle of the upper injector mount.
Clearence should be ok, it comes up between the the front and back runners, but there is a wire harness on top of the rail to deal with.
Posts: 2,148 |
How about getting someone to manufacture a phoelinic (sp?) spacer to make clearance between the fuel rail and the upper manifold? Result would not only add the appropriate clearance but also keep the intake charge a bit cooler.
Been keeping my eyes on this kit. Dont think I'll put down $1300 for a kit until I knew it fit underneath the upper intake.
But man oh man....the power that thing could make with the right fuel pump, timing and plugs.
Former owner of 1999 SVT Contour #555
Administrator
Administrator
Posts: 5,037 |
Originally posted by 99SVTguy: How about getting someone to manufacture a phoelinic (sp?) spacer to make clearance between the fuel rail and the upper manifold? Result would not only add the appropriate clearance but also keep the intake charge a bit cooler.
But man oh man....the power that thing could make with the right fuel pump, timing and plugs. Manifold won't go any higher without smacking the hood. Great idea though! -Chris
