Too many to count in Scotland! Depends on whether you like ale, heavy, lager, or just good ole fashioned Beer!!!
Righto been thinking about what you said so I'll repeat it back and you can fill in the blanks!
Use a external oil cooler, (using oil thermostat to control when oil enters.) The Cooler is connected using a sandwich plate which goes before the oil filter.
In the take off line from the sandwich plate insert a t-peice (small bore ID (6-9mm?). This will become the feed for the turbo.
Ok with the loop, for lubing the turbo on startup like an accusump (very clever!).
I take it you mean by putting put the oil return above oil level that it needs to be above oil level in the sump so you don't have oil going up the return?
Not sure what 'masked' means?
And this "small light non return valve in the pressure feed" really confuses me!
Cheers for the help m8! It's very appreciated, better make it a six pack of beer now!
Actually its fast approaching a case!
