Originally posted by DemonSVT:
ummm... No.
2.5L valves are shrouded; 3L are not. big difference. Not enough meat to unshroud 2.5
Valve sizes! big difference. And if you bring up putting larger valves in the 2.5 the shrouding will be worse and the cost rises tremendously.
Another bonus [b]IS dumping the stock waterpump pulley![/b]
Wrong.
The only difference in the combustion chamber aside from valve size is the extra metal shrouding the valves, including that flat wall that is next to the intakes.
I have done this and when I develop the film you can all see for yourself. Removing ALL the shrouding around the valves in the 2.5L heads basically removes the same amount of metal that is removed when the 3.0L heads are first milled at the factory. This shrouding IS the difference in combustion chamber volume. I measured the volume after I removed the shrouding around the valves and removed almost all of the flat wall next to the intake valves. There is plenty of metal to remove. The valve sizes are different, but the spacing between the valves is exactly (I have a picture with a micrometer in place!) the same on both heads. The valve seats on the intake are the same for both the 3.0 and the 2.5L except they are cut different. The outside diameter of the seat is EXACTLY the same. Easy to recut them to the same dimensions. (I've done that already)
The exhaust valves are a LOT smaller, and so are the seats. When the new seats are installed into the heads, they have the same amount of metal between the outside edge of the new exhaust valve seats and the intake valve seats. This means that they are positioned identically in the head. Again, I have measured this before and after so I know I am right. I have documented every step on this engine building/modifying process JUST for this type of occasion when I make a statement and have to prove it. You can take my word for it now, or wait until I get all the pictures posted.
Sorry to be a little emphatic here, but I have spent 30 days of my offtime maniacally measuring veryifying and photographic all this work. I have completed the head modifications and I am very confident as to the information I am passing out here;
WITH REGARD to the 1999 SVT heads and 1999 Taurus 3.0L heads.
warmonger
