Posts: 417 |
The Vortec kit for the regular duratec lacked 50hp from the SVT one. If I stuck the SVT intake manifolds (upper and lower), 65 or 75mm throttle body, larger custom exaust, SVT cams...that's probably only about 20-25hp... that's basic what else (besides re-boaring for new pistons) would someone have to do to achieve this?? I saw someone hitting 285 wheel HP (SVT), what the heck did he do to achieve so much more than expected???  IDEAS?????
99 Ford Contour SE Sport Manual V6 SVT front/ rear bumper /w Aussie grille Jet black Premier DEH-P740MP head unit matrix display, plays Mp3s!! 800 watt Kenwood amp 2 12" Polk Audio subs Blue "euro" headlights Eibach Pro-Kit springs 17" Enkei RS-5 White Indiglow gages
Posts: 7,329 |
The Vortech claims are based off of adding their S/C to a stock car.
The SVT with it's much better breathing (and cams & CR & etc) magnifies it's mods & the S/C much more than a Non-SVT engine would.
Posts: 1,611 |
One thing you forgot in your list is the higher compression of the SVT vs. regular duratec. This I beleive adds a fair amount to the mix as the air is all ready more compressed. Someone please correct me if I'm wrong.
Rick
The first Blown 3 Liter! "Drive it till the wheels fall off" -my personal motto!!!! 98.5 T-Red SVT #6180 Many Mods Buckshot77@aol.com Owner of 00 #1611 Silver Totalled on 10/7/01 SVT Parts for Sale
Posts: 5,805 |
Starting with a lower CR on the stoc 2.5 should allow you more boost than the SVT.The extra cam overlap does not help s/c or t/c,in fact you want less to stop the 'blow out' at boost pressures,s/c-t/c motors do not need the hot grinds.
Posts: 2,708 |
Only problem with that, Terry, is the limitations to the Vortech drive system. In order to run more boost that drive shaft has to be spun quite a bit faster with the use of a much smaller pulley... we have seen (And discussed at great length :D) what the stock drive system does with the stock pulley so going smaller to get more in this case can be more damaging to the engine & forced induction system in this case then if it were a turbo. -Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 5,805 |
I think you will find that the max boost is limited by the blow off valve ,not the pulley so an upped blow off would give you the higher boost without doing anything to the pulley at top end.
Posts: 2,708 |
Well the stock Vortech bypass opens at 10psi. At WOT on the dyno in 4th gear you are only pulling approx 7-7.5psi when the rev limiter kits. I guess I don't see how going to a higher psi setting on a new bypass would change that without increasing the impeller rpm's. What am I overlooking? -Mark
Posts: 5,805 |
So at whatt speed/gear DO you get to 10psi to open the by-pass?
Posts: 2,708 |
7500rpms in 1st usually puts me between 9.5-10psi 7500rpms in 2nd usually puts me at 8-9psi 7500rpms in 3 & 4 are about 7.5 on average. and in fifth approaching redline I haven't seen more then 6.5psi.
During WOT the bypass only seems to open during shift points & when the car hits the rev limiter. During regular driving the bypass is almost always open and the car remains in vacuum.
-Mark
Posts: 5,805 |
Confused? How can the by-pass be open(max boost) and the manifold be at neg atmos???...
