Hello, i have a 96 contour SE, and i am having trouble putting my system in, i can not figure out how
to get past the firewall. I have never had this much trouble before, i had a trans-am, put a system in it
not problem, put a system in my friends truck no problem. I know like over half of you have put a system in
your contour, so please help me out please, i need to get my system in my car. THANKS
Big Pimpin' 96 Contour SE.
2.5L V-6, 24VL DOHC, 5-speed
Phat System pushing
2 12" JL Audio W0
Pushing around 175hp right now at crank
purple neons under dash
APC fog lights with hyper white bulbs
Hyper white headlight bulbs
K&N air filter
Any comments wink
98 EO #587
Currently Dirt Jumping
On the fire wall go to the right of the brake booster...remove the felt mat...what do you see..????? wink
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
W
W
I have put tons of systems in cars before with ease too and let me tell you, the Contour (98' SE) was anything but easy! I ran the power cable through the hood pop hole down the drivers side of the firewall. I just knocked out the gromet and ran it through there. I was trying to avoid drilling through it by any means possible. Hope that helps you!
OK, thanks for your help. But what is beside the brake. Are you talking about the inside of the car. Do i just have to pull down the mat or what. I have no Idea what to do. Please can somebody just give me a run down from the battery past the fire wall. Where is the hood pop at. How do i run the power wire through there. Thanks for you help
Phat System pushing
2 12" JL Audio W0
K&N air filter
Terry is talking about the brake booster inside the engine bay not inside the car wink
The brake booster is right behind D in the picture wink
Thanks that helps alot, i am going to go put my system in my car as soon as the weather is better. Thanks you guys
Phat System pushing
2 12" JL Audio W0
K&N air filter
Ray Offline
Alienboy, check your PM's... how to enclosed..
Ray
s_r_haralson@sar.med.navy.mil WORK
srh@texas.net HOME
AIM: midnghtflm
YIM: midnghtflm smile
Check out my car!! (Profile Registry)
Have a Nextel two-way? check out my registry for my number!
Ray Haralson
Jacksonville, FL
srh@texas.net
YIM: midnghtflm
AIM: midnghtflm
NEWEST MOD: a BEAUTIFUL girlfriend for my one and only passenger.
if you move the carpet on the inside of your car...this is the fire hole
