Posts: 2,708 |
Does what ever program you are using figure in physics of a FWD vehicle?
-Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 592 |
So not counting David Zs 3.0L The best documented SC SVT times are 14.1s??? WEll can B.S. All day about what ifs...whats be run???? low 14s......Correct me if i'm wrong.
Ryan 98.5 Silver Frost Tour SVT 5979/6535 Born: May 15, 1998 Some Mods, still not fast enough.. 90 Black SHO
SVT Performance.Com
Posts: 1,682 |
Originally posted by T-RedSVT: My best MPH was 99.76 and that was a 14.12 run. 100 mph is like a 13.8-13.9 time... a higher trap speed DOES NOT EQUAL a lower et.
Posts: 1,682 |
Originally posted by RTStabler51: So not counting David Zs 3.0L The best documented SC SVT times are 14.1s??? WEll can B.S. All day about what ifs...whats be run???? low 14s......Correct me if i'm wrong. i'll agree to that. and add, if you want to hit LOW 13s you DAMN well better get some more torque (low/mid/high), cause without the tq, you will be lucky to get high 13s, and i don't care whose tranny you have.
Posts: 7,329 |
Originally posted by bret: i'll agree to that. and add, if you want to hit LOW 13s you DAMN well better get some more torque (low/mid/high), cause without the tq, you will be lucky to get high 13s, and i don't care whose tranny you have. Again you are wrong! :rolleyes: IT's TRACTION!!! Spinning through 3rd gear is no way to make good ET's. (heavy 17" rocks don't help either - but woulda coulda shoulda) I beat PhatSVT to 330' by a couple tenths. By the 1/8th had 2 tenths on me. (he ran almost 2.7 60' to my 2.2 - Imagine a 2.2 - that's ~13.6 @ 103!!!) TRACTION!!! Either that or I make over 200lb/ft at the wheels...  Your call... Get off the torque wagon silly... It's done run over your head... :p
Posts: 392 |
Originally posted by WorldTour: Does what ever program you are using figure in physics of a FWD vehicle?
-Mark Yes it does. Ill show you what I have for inputs and you can tell me what needs to be changed. In bold are the ones that are probably specific to YOUR SVT. The parameters are: displacement: 2544 cc location: front engined type: supercharged hp: 358 @ 7100 tq: 225 @ 6000 compression: 10.2 redline: 7300 start rpm: 1500 with clutch: dumpTransmission: 5 spd manual Ratios: 3.42, 2.14, 1.45, 1.03, 0.77 final drive: 4.06 drive wheels: front car test weight: 3100 % of weight on front wheels: 63% wheelbase: 106.5 tire section width: 215 wheel diameter: 16 in tire profile: 50%coefficient of drag: 0.32 overall height: 54.5 overal width: 69.1 ground clearance : 6.0 inches
Posts: 7,329 |
CR is 10:1 Redline is 7500 Test weight ~3250-3300 (driver & S/C)
Try 3k clutch slip (though you probably did optimum launch method)
Posts: 4,319 |
a higher trap speed DOES NOT EQUAL a lower et. Did you read what I was talking about? In the previous post RyeLou said: Originally posted by RyeLou: Corbett has had a s/c SVT for a while. It's not anymore, but he broke the 100mph barrier last week with it. I'm not sure if he got into the 12's, but I know he has been really close. So, basically I was telling him that 100 mph would not equal a 12 sec time in a S/C SVT. If he ran 100mph with the 60' times that have been discussed, it would equal about a 13.8 - 13.9. Originally posted by bret:
I'll agree to that. and add, if you want to hit LOW 13s you DAMN well better get some more torque (low/mid/high), cause without the tq, you will be lucky to get high 13s, and i don't care whose tranny you have. You better learn CPR if you want to discuss this, beacause that horse has been beat to death numerous times......
1991 GVR4 Lots of mods done.
Posts: 392 |
Originally posted by DemonSVT: CR is 10:1 Redline is 7500 Test weight ~3250-3300 (driver & S/C)
Try 3k clutch slip (though you probably did optimum launch method) On your car? Stock 99 and up Cr is 10.25:1 I believe? Redline at 6750. Is mark running to 7500? Test weight...looks about right?
Posts: 2,708 |
I have an early 98, so the C/R is 10:1 IIRC, stock rev limiter on my car was 7,000rpms. Currently it is 7,500rpms, but I will be using my MSD DIS-4 to lower it down to 6,800 for daily use once installed.
-Mark
