Posts: 926 |
21 PSI, isnt that alittle Extreme?? Your MPG will drop significantly and with that much boost you'd have a hell of a turbo lag.
Ben C '97 Zetec Sport ATX Pacific Green Fog Light Re-wire Many Mods My Site
You think you can beat this?.....Well, you probably can
Posts: 34 |
Turbo lag has absolutely nothing to do with the level of boost being made. It has to do with the sizing of the turbo. Modern turbos spool so fast that turbo lag is a thing of the past.
Thomas Gafa
Posts: 2,794 |
OMFG....fuel economy is all a sudden a concern with a 350plus HP 2.0L? Gimme a fuggin break...P.S. turbolag is a thing of the past man.....variable vane Turbos all but eliminate the lag......duh....MPG wtf is that?
Just call me Judge. People suck. Life begins at 170mph...until that point it is just boring.....
Posts: 926 |
Originally posted by 1Sick_Puppy: OMFG....fuel economy is all a sudden a concern with a 350plus HP 2.0L? Gimme a fuggin break...P.S. turbolag is a thing of the past man.....variable vane Turbos all but eliminate the lag......duh....MPG wtf is that? My bad man, I must still be livin in the 90's. I better get with it huh.
Posts: 3,248 |
"Numbers...the 'top end' kit is now giving us 350 BHP @ 340 Lbs torque with 1.5 Bar boost...prices are being worked out as we had to add rods etc (our original engine 'let go' at 335 BHP....)"
Terry, why did she "let go". Rods? IIRC Zetec has an iron crank, did you upgrade that as well? This is the kind of performance R&D I would love to see for the Duratec - find out what really needs to be upgraded and at what point. Nice work, your the MAN!
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 2,794 |
DAn, after re-reading Terry's post I would bet the rods let loose....he says he had to add rods to that kit so that is why I say it....but damn those are some sweet numbers.......
Posts: 5,805 |
Rods(caps) let go,crank is steel stock,boost max is dependant on initial cr and I dont give a damm about fuel economy ok!!!!
Posts: 2,523 |
Terry, is it even possible to turn the boost down when needed on this thing? I ask because the thought of my wife tooling around in my 'tour w/ 300+ HP at the wheels terrifies me just a little And she'd wanna drive it after that, trust me!
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 5,805 |
The 'boost pedal' is the one on the far right!!!
Posts: 2,523 |
Yeah, thanks Terry Guess I'll just have to hide the keys...
