#405103 08/04/02 11:29 PM
ok, The motor says 3.0 on top. It is a 97' Taurus GL. Is it a duratec?
2000 SE Sport MTX
Current Mods:KKM intake/removed res./custom Flowmaster exhaust/Eibachs/SVT struts/17x7 TSW imolas w/Dunlop SP9000 tires/fog fix/885 fogs/sound by Alpine,PPI,Audio Control,JL Audio,Boston Acoustic,Focal/Schroth 4-point racing harness.
Future Mods: Fully Zaino'd/front and rear sway bars(w/ custom BNOON powdercoating)/Strut tower brace/SVT exhaust/underdrive pulleys/SVT upper and lower intakes/Superchip/B&M short shift/SVT front bumper/and some others I haven't decided on yet.
www.stlsp.com
"Life's too short not to spend money----on your car!!"
"It's only wrong if you get caught doing it"
#405104 08/05/02 01:13 AM
If it says 3.0L on the top, it is probably the Vulcan
A 1998 3L Duratec
A 1997 Vulcan
Tony Boner
#405105 08/05/02 01:55 AM
Taurus GLs were the bottom line of Tauruses of that generation. Chances are very slim that it is a Duratec.
99 Black SE Sport ATX
Running on E1 SVT rims with Dunlop rubber
Pioneer DEH-P3100 CD receiver (2 channels of the amp blown, officially declared dead)
Pioneer DEH-P440 CD receiver
Pioneer TS-6865 6x8's in the front
Pioneer TS-6867 6x8's in the rear
Pioneer TS-WX121 Sub with a Pioneer GM352 amp feeding it
#405106 08/05/02 05:09 AM
BTW - Isn't is 98 and up 3L Duratecs that are compatible anyway???
2000 SVT #674 - Check it out!
#405107 08/06/02 12:55 PM
You can actually use the older '96-'97 blocks too, just need to modify the trans bolt pattern by drilling and tapping a hole as well as some slight cutting to clear the starter position with out MTX. Someone on here actually did that I think... I don't remember who it was though... Not quite as easy as the newer '98-'99 blocks, but you can do it. wink
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
