99 T-RED SVT 50,555 Miles and counting as off 7/12/2002 born jan 99 UR underdrive pulley A Pillar Guages w/ AIR/FUEL VOLTS OIL PRESSURE "how to" members.aol.com/samplewon/apillarguageinstall.jpg B&M short throw shifter Eibach Springs BAT Sturts White Faced HVAC 2 ALPINE TYPE R 12" and ALPINE 1507 V12 AMP Cup Holder Upgrade PIAA super white Lows Whelen 90watt 6 bulb strobe kit Front end motor mounts
Mods waiting for install 3L(job has alrady begun, 3L totaly stripped.) Quaife LSD Apexi s-afc Mirko splitter
the turbo SVT is running 30# injectors, with 300 hp at the wheels, with an S-afc running the car 50% lean, and its still WAY rich
so, uh unless you need more fuel than a turbo contour..
95 SE Champagne Mettalic True Dual exhaust with X pipe and Redline mufflers KKM Tru Rev intake H&R Springs/KYB struts Apex-i S-AFC 65mm Throttle Body 17" Ace Spades 4 Pt Racing Harness Window Tint all around New Engine @ 117k kilometers G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass" quote from awed CEG'er after i chopped my hood and threw on scoops
kris.... can you gve me more specs avbout this or send em a link as to where i can learn more about the turboed svt.
