Posts: 452 |
I ran into a 12 second mustang running 42#injectors and a whole bunch of stuff to his car.. he told me that i shoudl run 30# injectors instead of 24#ers.. he said it would give a much bigger uotput and it would camcel out he FMU. Question: is this a good idea and wat kind of Fuel Management Unit is on our cars as of now?
Second question..: Should I remove my secondaries? My IMRC is shot to chit and im tired of them not opening up when i nee then the most. Shuld i get rid of them or buy a new IMRC. also.... what effect would the removed secondaries give to the 3L...
99 T-RED SVT 50,555 Miles and counting as off 7/12/2002 born jan 99 UR underdrive pulley A Pillar Guages w/ AIR/FUEL VOLTS OIL PRESSURE "how to" members.aol.com/samplewon/apillarguageinstall.jpg B&M short throw shifter Eibach Springs BAT Sturts White Faced HVAC 2 ALPINE TYPE R 12" and ALPINE 1507 V12 AMP Cup Holder Upgrade PIAA super white Lows Whelen 90watt 6 bulb strobe kit Front end motor mounts
Mods waiting for install 3L(job has alrady begun, 3L totaly stripped.) Quaife LSD Apexi s-afc Mirko splitter
Posts: 3,419 |
30# is way more than you need. You want to use the smallest injectors that are sufficient for maximum fuel needs. The bigger you go, the more problems you are going to have trying to get them to work properly. If you have a set of injectors that meet your needs at maximum flow demand, putting a bigger set on will net you exactly 0 hp.
Posts: 452 |
ok i see what about my second question.
Posts: 724 |
who said bigger is better?! Oh must be those RWD muscles car maniacs..... :p
98 V6 Lots-o-mods SOLD 88 Daytona Shelby Z TII (The beast) 87 Daytona Shelby Z TII (Holy 20 psi of boost batman!) Mods- 3" Downpipe, Hi-Flow cat, 3" mandrel bent exhaust with Dynomax Ultra flow. Manual boost controller, TurboXS blowoff, 5th injector, large canister wastegate, Nitrous Express go-fast-be-happy kit, ported exhaust manifold, ported intake manifold, upgraded motormounts, eibach springs, strut tower brace. Oh and 20 PSI to boot.. my oh my...
Posts: 539 |
your more then likely gonna be running rich with the 24# injectors. i had to lean my car out one i went on the dyno and a wide band 02 to achieve a good 12.5:1 ratio which is ideal for max performance. Before u take the plunge i would say get the SAFC cause u will to tune those big injectors anyway.
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 452 |
check the sig under mods waiting to be installed Giacomo
Posts: 539 |
WELL EXCUSE ME ![wink wink](/ubbthreads/images/graemlins/default/wink.gif)
Posts: 452 |
chill homie no arm intended. ![smile smile](/ubbthreads/images/graemlins/default/smile.gif)
Posts: 539 |
hey pick up the last issue of SCC last aritcle talks about variable intake lenghts and other types of intakes and the benefits of them
Posts: 452 |
OK WILL DO..is the contour mentioned in anyway?
