Posts: 115 |
So i have a theory, wether or not it proves to work is another story, however it's always worth trying. (question, first thoery later)
Question: Which vehicles in 2001+ had the plastic intake similar in design to the Taurus one. I already have an upper, but have found out I will definitely need the lower also, so I just need a lower to matte up to my 2001 Taurus intake.
Theory: I beleive that the oval port 2001+ plastic intake manifolds will provide better all around throughput than our split port design. The reason why I think this, is reading from Terry about the X-area being larger on the ovals than the split port, the fact the manifold is plastic (and very smooth), no wall after TB, and better location of intake filter for possible future ram air considerations, and finally price, I paid just to day 50$ for an upper, EGR, TB, TPS, IAC. Heck say I spend another 50$ just on the lower, that will mean I spent a total of 100$, AND i get an SVT equivalent TB in the process, which alone is worth that much. I also wanted to mention I do not have an SVT upper, and this is my solution to the 260$ price of the upper.
2000 Cougar V6 MTX Black Visteon GFX Kit with Razzi rear skirts, Ground Controls, YoDude Exhaust, Ractive Filter, Custom Interior, Custom Loud Stereo, and more... See Her Here
Posts: 460 |
Will the Oval Port lower mate up the the heads on a 2.5L Cougar? Or does that not even matter?
This is an interesting find Pierre. I would be willing to try the same thing on my Cougar and dyno test it for the group, just so we all know. Right now I have the SVT Upper/Lower and TB on my car. It would be cool to see what the difference in power is, if any.
Nikolas
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Posts: 5,805 |
This is 'old news' re 2001 3.0 'oval ports & central injector position'....
Posts: 460 |
This is 'old news' re 2001 3.0 'oval ports & central injector position'.... ..........and your point is? anyways.... What about the heads? Do the oval port lowers mate to the heads on the 2.5L engine? Nikolas
Posts: 3,562 |
Won't mate up to the 2.5 heads without an adapter plate and a little machine work to "point" the port entrances a bit to work with the oval intake parts. I have a 2001 3 liter UIM and LIM if anyone wants it to play around with...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1 |
Is he allways so helpful?
Posts: 539 |
yes they can work as brad noon said with adapter plates.
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 115 |
Posts: 5,805 |
On a 2001 oval head the best upper & lower is the ST220.......
Posts: 460 |
Cool...so these can work with adapter plates.
Is anyone selling these? Does anyone have a prototype or something that can be duplicated?
I would really like to run some tests to see what makes more power and get this info out to the Duratec Community. It is something we all need to know. If anyone is willing to work with me, then I can front the cash to get parts made, do the dynoing, tuning, etc.......
Nikolas
