1
1
Does anyone know if the parts include the gaskets for the spark plug holes? This is the part numbers I got F5RZ6584B and F5RZ6584C
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
When I got my valve cover gaskets from Bill Jenkins, the spark plug holes weren't part of the set. i.e., seperate part number. I don't know what it is however.
'Fel-Pro' Part # for the spark plug tube seals is #95720.Fel-Pro are the OEM to Ford,they do every gasket and seal for the enigine, either as two kits, top end re head gaskets etc, or oil pan/bottom end or piece by piece...got to a Fel-Pro dealer/ outlet.... wink
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Every Felpro dealer here in Des Moines doesn't list anything for the Duratec engine family... Even had one call the distributor to double check... Any other part numbers out there for the entire kits you say are available, or is this dipping to far into the HMS knowledge wealth? I like using Bill Jenkins for my parts, but with the local contacts we have here at parts stores we should be able to get parts that they say don't exist if we have a number to go on.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
Head 'set' is # HS 9038 PT, 'Conversion Kit' (includes oil pan gasket, oil seals etc) CS 9038...
V6 MTX
Thanks Terry!!! laugh This one should make it into the parts/sources links from the main site to keep for good.
Brad Noon
'99 SE MTX
1
1
Oil seals? I thought there's only an oilpan gasket? Is there something more?
Car Pics
The 'Conversion' gasket kit contains:-Oil pan/w-pump/drain plug/rear main oil seal/front crank oil seal/oil seperator/oil pump pickup/oil cooler O ring...
V6 MTX
1
1
Oh! That doesn't include stuff like valve cover gasket, head gasket, or anything above the short block right?
Car Pics
I listed two kit part numbers,one for the head set and one for the conversion set and I gave you the Fel-Pro part # for the spark plug tube seals...what else!!! :rolleyes:
V6 MTX
