#404715 05/30/02 09:13 PM
BIG JAY Offline OP
WEll the shop that was goning to do the swap backed out.So now I have to find some one to do it. DO you guy have any think in mind. I have to towe it to the place were it will be done.
thanks
98csvt(red)white 19''Axis se7ens on toyo 225/35/19's injen intake,cust exhaust, High Rev's racing clutch,and flywheel .whatever its takes to run 12's (system)Eclipse 5442,Boston 6 1/2" pros, Eclipse 5x7 point scourse,PPIpc4400,PPIpc2600(chrome),power cap,2 12"JLW6
YOU WILL RESPECT THE FAMILY CAR
Sho-Shop, or David Z.
DO you already have all the parts?
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
sho shop will do it since u have a (an) svt....they were hesitant to commit to my car because of the atx
quite frankly i didn't get a real comfortable feeling about them installing an engine either way...if u deal with them it might be best to really talk to them to get a feel for their knowledge
i wonder david z would charge confused
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
O
O
What about brad?
where u located
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
BIG JAY Offline OP
I am in fontana about 45 mins from la.After all the shops tring to rape me ford will use the hile coil. SO i will have the motor sitting around till I have all the $$$$. I will do the swap on about 3mths.
sorry, im lost...does this mean ford is doing the work for u confused
