Page 1 of 3 1 2 3
#404458 04/29/02 05:01 AM
I was reading on Edmunds that Jaguar is coming out with 3.0L supercharged version of the Duratec that will be placed in the AWD (or 4WD?) X-Type sometime in the 2003 model year. Any possibility to START using that platform? Or would it actually be cheaper to use the current 3.0L and SC that? Supposed output over 300hp, and it'll be factory reliable when it comes out. Just a random thought.
TJ
T.Red 1999 Contour SVT
God-Awful exhaust tips frown
Dunlop SP5000 (225/50-16)
email: the.jack@verizon.net
The Xtype Jag motor is an upgraded LS 3.0 NOT a Taurus.I have LS motors for sale and yes they,if you have the $$$, be upgraded to the SC Jag spec.... wink
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Do they also fit the Contour like the Taurus 3L?
TJ
The LS needs more prep re fab/m-c/ etc but it does fit... wink
V6 MTX
Originally posted by The Jack:
...... AWD (or 4WD?) ........
Not the same! They are AWD!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
WooHoo......force fed 3.0L AWD...now we are talking...
Just call me Judge.
People suck.
Life begins at 170mph...until that point it is just boring.....
F
F
I would start preparing now by getting an LSD, clutch and flywheel bought and installed by a qualified technician. I say this because IIRC, the blower being used will be a roots style blower that makes mad torque down low ... kiss you MTX-75 stock diff goodbye within the first year unless you abosuletly baby the car and drive like a grandma. If that's the case, I don't see you needing either these upgrades or the blower to boot laugh
Also, at that HP/TQ rate, you will need to start worrying about CV joints, Wheel bearings and Gear sets too. Not to mention the obvious rods and pistons. I will probably get a lot of flack for this, but the truth is the truth: do it right the first time and you will not have to worry about doing right the second time.
Some people will no doubt comment that the factory rods this and the factory rods that, but guess what ... when you do actually bend a rod, best case scenario, only the rod is bent and no other damage occurs. Parts cost $150-$180 ... labor ... BEND OVER! You are better off doing as much preventative maintence as possible ... in this case, replacing damn near everything internally.
Best Regards,
Trevor Cole
New Edge Cougar Forums
One thing about this new motor - if they put stronger rods in it we may be able to use them because the 2.5 uses the same rod as the 3.0, including the Jag IIRC. Factory forged rods! laugh
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
If you can afford the new Jag motor why are you driving a contour? personally I would take the whole car after all its only $50k or so This motor would cost more than any contour is worth sorry but I cant help being realistic it comes with age I guess
'69 Chevelle SS
'99 Mystaque GS
2000 dollars where are you getting your cars at slow poke? That is the cost of the LS motor which puts out close to the same horse and torque as the jag. Even with terry doing prep work your lookin around 4000 dollars. Guys pay that much for the vortechs with Installion and the LS motor matchs the torque output of the vortech. Hands down I would buy the LS motor over the turbo and The supercharger.
Dustyn
Red 1998 SVT E1
95 Mustang GT
Yeah there both slow
New ram clutch for sale
Sho shop pullies and belt for sale 30 bucks
Page 1 of 3 1 2 3
