Posts: 83 |
I was wondering what the performance increase is after you swap in a 3.0 Also, what mods are available for it? Can you keep the same tranny? Perhaps someone could point me towards a website with this information.
98 E0 #848 KKM Rear SVT emblem (Thanks nyceboi!) .. more to come
Posts: 1,687 |
www.bnmotorsports.com has some good information on what you'll need for the swap. also you'll want to use the search feature in this particular forum to find a wealth of information on the topic. after you learn more you may want to contact some guys on the CEG like Terry Haines, Brad Noon, warmonger, david z, buckshot etc. among others to help you out. I myself am wondering what some of the top 1/4 mile and 0-60 times are for a 3.0 LS engine swap...
Posts: 5,805 |
I would advise the LS 3.0 Vs the Taurus as it has more potential re moving up to the Jag X type specs.The biggest shorfall of the Taurus 3.0 is the valve train design..it does not lend itself to much tuning over and above stock.The LS/Jag on the other hand has far more potential...depends how far you want to go...and how fast!!!
Posts: 180 |
Terry,
Does the LS/S-Type #.0L bolt right in or is there some fabrication involved?
What do you think the Taurus 3.0L is good for N/A?
Mark Wilson
98.5 SVT Contour 93 SVT Cobra #1824 93 SVT Cobra R #84 1972 Mustang Convertible 1970 Mustang Mach 1 1967 Sunbeam Tiger
ALL MODIFIED!!
Posts: 5,805 |
More fab/m-c/mods than a Taurus,trans fits etc.You can mod the Taurus 3.0 NA the same way they are doing on the Taurus sites but the LS/Jag has far more potential....
Posts: 2,260 |
buch svt, go to David Z\'s website , scroll down and check out the 3L FAQ, it explains a good amount. James
SVT with CE light mod and a camera mount. Naughty Pictures Why yes it is true, I am on my third engine.
Posts: 16 |
So Terry, what would you say a crate or junkyard LS/X-type engine would cost?
99 Mercury Cougar V6 MTX Sport & Convenience Pkgs Weapon-R Borla Dual Carbon Fiber Sho Shop Y-pipe Energy Suspension Motor Mounts B&M Short Throw Shifter AMSOIL Race Synthetic
Posts: 5,805 |
Posts: 244 |
It is tempting, so tempt further There has been a great deal of info of what it takes to put a Taurus 3.0l in the Contour. Does the LS need anything else? Can it be converted to return? Tempt me not for I am weak, oh what the heck, set the hook and reel me in.
Scott 96 SE, MTX, BAT 22mm rear anti-sway bar, BAT springs and Spax struts 96 Caprice, 9C1 Rayon is made of wood!!!
Posts: 5,805 |
Why revert to return...upgrade to returnless as the next generation of tuning and aftermarket is moving in that direction...
