Originally posted by ScottK97SEMTX:
Originally posted by warmonger:
[b]Ruler? Funny. (not)
I used a Mitutoyo Digital micrometer, accurate out to .01 mm, +-.005 mm.
The reason for the variation was because the diameter for the runners was not the same in both the x and y axes. Therefore if they were more eliptical then I put down the full range. The SVT upper manifold can be expected to be eliptical because of how the Xtrude honing forces putty through the tube.
warmonger
Actually, IIRC from the swap to my dual honed upper, the stock 2.5L is more squished/elliptical than the SVT was. I figured that the EH rounded it out some.
--- what's wrong with measuring with a ruler
http://www.frontiernet.net/~kauffman/pictures/svtupper/2Xhonesvt.JPG
http://www.frontiernet.net/~kauffman/pictures/svtupper/standardMY97.JPG
--4/5/02 frontiernet server appears to be having trouble--[/b]Nice pictures.
I looked at them and for the first picture of the dual honed manifold, I came up with the following two measures, one low and one high:
lower estimate: 14/32" + 27/32" = 41/32" = 1.18125" = 32.54mm
higher estimate: 14/32" + 28/32" = 42/32" = 1.3125" = 33.34mm
For the second link with the stock port I came up with the following:
11/32" + 28/32" = 39/32" = 1.219" = 30.96mm
Now compare that with the post that I made concerning the measurements on my manifold outlet port diameters. For the secondary outlet port I listed a range that was:
32.8 - 33mm or roughly 33mm overall
Compare that with the measurements from the picture of the dualhoned upper that I just calculated:
32.5-33.3mm or avg.= 32.94 or roughly 33mm.
By my book, that is the same as my measurements, and should serve to lend support to the measurements that I made.
Thanks ScottK97.....
warmonger
