Page 2 of 3 1 2 3
#404011 03/22/02 07:19 AM
svttour Offline OP
Originally posted by bnoon:
Just got to tell you since it sounds like your first time... lable and number everything as you take it off. A lot of pictures can help you reassemble it too. The cams will be the trickiest part for you to get timed being a newbie, so pay special attension during that disassembly. Long way to go yet man... you do have the Ford CD ROM, yes?
You know it buddy Ive taken a pic of every screw and every spot a part belongs. I have over 100 pics and Im just getting started. I do have the Ford CD rom but its a bit confusing Im looking into it and checking out the cam assembly. You are totally right I just took off the valve covers and its time to jump in the deep end. I have some help from a fellow Ceger helping me with removing the cams I will be using a sharpie to label the correct displacement for the cams but i still dont see why I shold do this when I will be running SVT cams anyways.. Im looking into the hardest part of all as we speak. Im thinking of senging my LIM and my 3L heads to be machine matched and P&P. This is hard because as all you know the 99 block has primary and secondary intakes and the 2001 block doesnt. So i need to match them in order for this puppy to pur. Im glad you are helping me out along the way man this means alot to me.
I cey mike i think you should leave your .02 cents in your pocket Ive had enough criticism from people and its time for me to prosper.
To everyone that helps me I extend a gratifying thanks and I know this is what being part of a organization or enthusiasts is all about. Keep up te good work guys as I am doing.
99 T-RED SVT
50,555 Miles and counting as off 7/12/2002
born jan 99
UR underdrive pulley
A Pillar Guages w/ AIR/FUEL VOLTS OIL PRESSURE "how to" members.aol.com/samplewon/apillarguageinstall.jpg
B&M short throw shifter
Eibach Springs
BAT Sturts
White Faced HVAC
2 ALPINE TYPE R 12" and ALPINE 1507 V12 AMP
Cup Holder Upgrade
PIAA super white Lows
Whelen 90watt 6 bulb strobe kit
Front end motor mounts
Mods waiting for install
3L(job has alrady begun, 3L totaly stripped.)
Quaife LSD
Apexi s-afc
Mirko splitter
#404012 03/22/02 07:44 AM
svttour Offline OP
motivation is all it really takes some people think something is beyond them to do but really they are probably just too scared or lazy to try.
-Terry m scott
99 T-RED SVT
born jan 99
Eibach Springs
BAT Sturts
White Faced HVAC
Cup Holder Upgrade
Quaife LSD
Apexi s-afc
Mirko splitter
#404013 03/22/02 05:38 PM
Go get 'em svttour!!!
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#404014 03/22/02 06:11 PM
I
I
-Terry m scott
I applaude you for doing the unbelievable, but I think it's not about being lazy or unmotivated to try, it's about wasting valuable time, resources, and money on a project that you have no knowledge about.
Granite, you dont need to be a rocket scientist to build an engine, but you must have some type of techinical aptitude and background for this kind of work.
I hope it works out for you!
99 Range Rover 4.6 HSE
Mystery Car??????
#404015 03/22/02 07:49 PM
JVT Offline
OK JVT you asked for it I just got home from the shop and did some more work to the engine. now its almost bare.
OK.
:rolleyes: Thought you said you had the motor stripped?
Anywho, the fun is starting now. Enjoy it.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
#404016 03/23/02 05:06 AM
Y
Y
good luck, When you pull the front cover, Do you have to pull the heads first?
Yankeyspeed: American power and ingenuity
95 SE -Stock enough
Yeah my car has a baby seat, its still fast.
#404017 03/23/02 05:18 AM
svttour Offline OP
Hey I puled both valve covers off and im going to mark the cams and camshafts and remove them first. after that im removing the heads and tehm all the otehr b/s that is still on it. Im pondering on sending the heads and lower intake manifold to extrude hone to be p&p and matted to match and seal perfectly. any ideas where I can get this done under a grand?
99 T-RED SVT
born jan 99
Eibach Springs
BAT Sturts
White Faced HVAC
Cup Holder Upgrade
Quaife LSD
Apexi s-afc
Mirko splitter
#404018 03/23/02 05:21 AM
Originally posted by Icey Mike:
[QB]I think it's not about being lazy or unmotivated to try, it's about wasting valuable time, resources, and money on a project that you have no knowledge about.
Granite, you dont need to be a rocket scientist to build an engine, but you must have some type of techinical aptitude and background for this kind of work.QB]
IceyMike: He's gotta learn somehow... :rolleyes:
I commend him. The biggest satisfaction Sam will have wont be the surge of power as the tach sweeps into the unknown, but knowing he did it on his own!
Jonathan
98 SVT E0 #4290
#404019 03/25/02 08:01 AM
svttour Offline OP
Once again I thank all of you guys for egging me on and I am working on it little by little each day so hopeflly in 2 minths i will have it completed. I am giving such a long end date becuase of a shortage of funds I have. When I recieve funds I will be sending the LIM and 3L heads to jiako so his mechaninc can do the matting and change all the necessary things that he did in order to have a smooth burn. Then after I get it back from him In sending the heads to extrude hone for I have a buddy that is getting me a great deal for P&P. after that I dont have planned yet..
I need some designs on the modded fuel rain and specs so I can start getting an idea as to how i am gonig to put it together. as for everything else Ill ask if i need help
peace for now.
sam
99 T-RED SVT
born jan 99
Eibach Springs
BAT Sturts
White Faced HVAC
Cup Holder Upgrade
Quaife LSD
Apexi s-afc
Mirko splitter
#404020 03/26/02 02:49 AM
W
W
Go for it!!
You will learn alot and you can take much satisfaction when it is done.
And hey, if you break something it's only money.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
Page 2 of 3 1 2 3
