Page 3 of 3 1 2 3
Originally posted by jiako:
I will be 200 fwhp very soon.
I hope to say the same thing soon... laugh
2000 SVT #674 - Check it out!
W
W
Originally posted by bnoon:
Originally posted by David Z:
[b]The SVT ecu was programmed from factory like that, many others who have dynoed their SVT got similar results.
Yes, but those were factory SVT motors... with the 3 liter, he's the first to run rich with 19's that I know of if that's what he's running...[/b]
Wrong.
All the dyno #'s that I posted were run with the stock 19# injectors, Including the last run of 217 fwHP with the pipes down. I was also running rich, below 12:1 at 6750 rpm.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
W
W
BTW
Good numbers Jiako. Interesting how those numbers are about the same as my first dyno with stock intake and stock exhaust. I dropped the pipes on my engine and made the 217 HP.
We have essentially the same compression, same size valves, etc., so I guess it shouldn't be a surprise.
That was when I went out and put on a bigger exhaust, but then I ran into the low rpm driveability issue.
warmonger
Engine: 3.0 power!
Check them out at
jiako Offline OP
what kind of problems are u having and what exhuast do you have....size piping
one question why did you do all that work with putting larger valves in and machining the combustion chambers instead of getting 3L heads.....was it a cost issue
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Page 3 of 3 1 2 3
